| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I love my old 49 but would really like to put in power assist and/or disk brakes. The truck is stock, 16" 6 bolt rims. In a word, can this be done simply enough without making major changes or relocating the pedal? | | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | i have seen a lot of kits, as far as how easy it is i can't tell you, but they are meant to be a bolt on type of deal.
www. chevyduty.com is one place that has them for your truck
2003 ford lightning 1959 chevy 36
| | | | | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Go look at tech stuff and see what I did to the 39
Didn't need a booster never will | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i had a power brakes unit put on my 54/3100 last summer and it was well worth it. it is a bolt in unit from brotherstrucks.com. i had it installed by a shop because in my case i had to have the floor shift moved and i can't weld. the brakes are a little touchy lke 70s camaros but work fine when you get familiar with them. i would recommend a separate proportioning valve, they said it was not needed but i think the touchyness would go away with it, will be done in the spring.hope this helps. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
