3 members (J Lucas, HandyAndy, TUTS 59), 39 guests, and 3 robots.
Topics128,036
Posts1,055,448
Members48,422
#43041 06/07/2004 7:00 PM
Pal
Offline
Anyone ever mount an NV 4500 5 spd behind a 250? A tranny shop is recommending that I use one.
35 + years of rollin' steel!
#43042 06/08/2004 2:15 AM
I think it'll bolt right up, pretty much. There will be some mods necessary, depending on your application.
There are less expensive options for manual shift overdrive. T-5, A-833, etc. Depends on how little you want to spend.
-ftyler
#43043 06/08/2004 2:45 PM
Pal
There was a good article in one of the recent Custom Classic Truck or Classic Truck on this swap for a task force truck. It was a pretty straight forward swap.
Ralph
rtlopez@shipleysystems.com
48 Chevy 3600 w/235
48 Chevy 3100 w/235:
You cant see the smoke on a dirt road.
#43044 06/08/2004 11:05 PM
Pal thay are a littel more expesenive then some outhers but I think thay are far stonger
Advance Adapters sell all kind of adapters to use this trany in just about anything
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
#43045 06/09/2004 2:54 PM
Pal
Offline
I'm not sure if that's going to be the option (NV 4500). The quote I just got in was $2200, including a new 4500, conversion kit (bell housing, fork, ball), Clutch linkage bracket, and shifter handle. While that's a good price for a "new" 5 spd, it may be beyond my budget.
I just don't want buy something from a junkyard and slap it in. The old girl has been running for 35+ years. She deserves a good tranny. Thanks for the advice, guys.
#43046 06/09/2004 3:18 PM
Take a look at the NV3500 as found in 4.3 V-6 powered full size and S10's, not the 4 cylinder, 91 and newer tranny.It has an intergal bell housing, but will bolt up to a small block V-8 or 250 type 6 no problem.However the bellhousing is set up for a hydraulic clutch and the tranny uses a electronic speedo drive which you will have to adapt somehow.The NV 3500 has a 300 lbs ft torque rating, plenty for your engine.They sell rebuilt online for around 1200 bucks, 500 bucks or so in a recycle yard.
