3 members (baldeagle, Ponchogl, Stovebolt48), 72 guests, and 6 robots.
Topics128,021
Posts1,055,346
Members48,420
#427230 06/27/2008 6:07 PM
Does anyone have any experience with this product? I understand it helps from burning out your points and gives the engine a boost. True?
When you find yourself the victim of someone's bitterness, ignorance, smallness or insecurities, remember it could be much worse - you could be them.
https://www.facebook.com/Bluebird-Screen-Printing-245546842130721/
jdl Offline
Search. I and probably a few others have asked this question and all responses were positive.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #427246 06/27/2008 7:01 PM
It is an excellent product. I know tons of people with Pertronix and it just works. Highly recommended.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Good.....but for the money Langdon's HEI is way better. The Petronix relies on your old dizzy. T/C Steve
Thanks guys!
i had a pertronix for about 5 years and it worked great but my distributer was worn so i went to a mini hei from langdons but only have 180 miles on it.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
gmchix #427295 06/27/2008 10:09 PM
The Pertronix system replaces the mechanical points with an electronic trigger unit that does not wear or burn like points do. Some people have had reliability problems with the system, with unexpected failures to operate that shuts the engine down with no warning. It's a good idea to keep a set of points and a condenser in the glove box to install in case of a sudden stop.
My nephew's Plymouth Roadrunner 383 engine has that system, and my only gripe about it is the fact the reluctor that installs under the rotor is a little sloppy. That makes the ignition timing inaccurate by whatever amount it is able to move back and forth. It would be a pretty simple fix to just glue the reluctor the the rotor, I guess, or use a piece of shim stock to take up the slack.
Any bushing wear or looseness where the distributor shaft fits the housing will also allow timing errors, so start with a wear-free distributor, or a rebuilt unit.
Thanks! I love having those who come before me with making these changes! It makes my project run a lot smoother!
Who,Me:
I was considering the Petronix for my 65 C-10 with 230 L6. I don't know about the Langdon HEI. It it just as easy to install?
Mike, the quick fix for your 230 is to get a wrecking-yard HEI for a late model 250 or 292. It's a drop-in swap, and GM standard repair parts are available at any FLAPS.
Tom Langdon's web site has an HEI unit for a 230. I guess a junk yard is an option also. Tom checks out each unit for proper performance in fact on the bottom of the units you can see a hand written "OK" in white lettering. He stands by his products and will help with any technical questions via email or phone. In tech. articles on this site a guy converted a dizzy with a file and another guy said it was too much work and to buy a Langdon's? Its all good just personal choice.....T/C Steve
Thanks Jerry. Did the HEI come standard in the late model 250/292? I thought all those engines came with standard points and condenser. Most wrecking yards don't have the older parts, so I'll have to search.
Mike
Got my Ignator and installed it! Easy to install and seems to make the starting a bit easier. Still can't drive the banana because I haven't converted the brakes. frown
There are two basic I-6 HEI distributors, one with a remote coil, the other with the coil integral with the cap like a V-8 HEI. The basic module and pickup coil is the same, with only minor wiring differences and a different distributor cap. Either one should be a drop-in fit to the block on your 230. I've done several conversions on 216/235/261 engines with a little machining to correct oil pump drive concerns. Nothing like eliminating that periodic point/condenser change and getting a hotter spark in the process!
