5 members (diseasel, Bill Hanlon, 59 fleet, Phak1, Wayne67vert), 109 guests, and 1 robot.
Topics128,035
Posts1,055,566
#429 01/05/2005 6:18 PM
I love my old 49 but would really like to put in power assist and/or disk brakes. The truck is stock, 16" 6 bolt rims. In a word, can this be done simply enough without making major changes or relocating the pedal?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#430 01/05/2005 6:51 PM
1 Offline
i have seen a lot of kits, as far as how easy it is i can't tell you, but they are meant to be a bolt on type of deal.
www. chevyduty.com is one place that has them for your truck
2003 ford lightning
1959 chevy 36
#431 01/05/2005 7:17 PM
Go look at tech stuff and see what I did to the 39
Didn't need a booster never will
#432 01/05/2005 8:50 PM
i had a power brakes unit put on my 54/3100 last summer and it was well worth it. it is a bolt in unit from brotherstrucks.com. i had it installed by a shop because in my case i had to have the floor shift moved and i can't weld. the brakes are a little touchy lke 70s camaros but work fine when you get familiar with them. i would recommend a separate proportioning valve, they said it was not needed but i think the touchyness would go away with it, will be done in the spring.hope this helps. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
