| | | Forums66 Topics128,024 Posts1,055,392 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 103 | I installed a GM 10 bolt rear end in my 41 3/4 ton long bed and I was wondering if the stock parking brake cable would work with the drum brakes on my rear end. The guy I bought the rear end from says it is from a 75 camaro. Any help or suggestions would be greatly appreciated.
Thanks James
If it was easy, everybody would be doing it.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Most anything will work if you are determined enough. You may have to fab something up to make it work. it would work on my 51 because thats what I have. Of course my E brake is foot operated and yours may be attached to the tranny. If it is it should be pretty easy to make it work. If not you can always carry a chock or two.
~Jim
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | my problem with my 54 was the length of the cables, shorter. but a clevis and a all thread work to bridge the gap. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
