| | | Forums66 Topics128,049 Posts1,055,678 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | I've searched and searched, I can't find my bookmark for a web page that had listed serveral compatible late model wheels that are compatible with AD trucks or it stated their #lugs/spacing, center diameter, wheel size, backspacing and width.
Does anyone have such a bookmark?
Specifically, I found a set of Alum Alloys for a 2001 Chevy 1500 and was wondering if they will work on my '54 3100.
Thanks. | | | | | Joined: Mar 2006 Posts: 143 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 143 | I don't think they will fit-- the backspacing is wrong-- try them (with a tire mounted)-- I found that the rear tires rubbed the bed-- didn't try the front ones but I've heard there is a problem with tie rod interference. The only chance you might have is if you find 215 or 225 series tires. Good luck-- let us know if you find a way to make them work. Glenn | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | sfsutton: others will come along later with more info but I have read many times that the 6lug wheels off the earlier Blazers and the Surburbans will work. I think it was wheels off the 4x4 Blazers and all you have to do is change the center caps.
The earlier sixties model 6 lugs will work and is what I currently have on the 52panel.
As for the tie rod there is an aftermarket that will work and give you some room for more offset and bigger tires but when I checked several months ago they were rather expensive. I had the part number somewhere aroung here.
A lot of wheels will fit....my son in laws Toyota wheels will fit and look nice but I didn't have the front hubs on to check a front tire. I've heard some Mazda wheels will work but then I heard there is problems there. Either back spacing/tie rod problems or maybe it wss the bolt pattern off some???
This should get you started until someone else comes along. I do think the earlier Blazers and Surburbans is the way to go and that the rally type look good on an AD. I'm not sure what the years but I "think" up until 87 or maybe later on the Blazer? | | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | the Chevy K5 Blazer "Rally" Steel wheels do work on AD trucks, I have them fitted on mine. They're 15" x 8" rim width.
Stuart. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Up to '87 4x4 wheels will work, 3 1/2" backspace, 0 mm offset. You can use wheels off of a Japanese truck, they will physicly bolt up, but the tire will rub the drag link on a left turn, especially if you have anything wider han a 225 tire. The late model 1/2 ton and light 3/4 ton 6 lug wheels won't work, the backspace is too deep, nor will the wheels from the Colorado/Canyon (right bolt patters, but even deeper backspace), and the Trailblazer/Envoy wheels use not only a deeper backspace, but have a different bolt circle size.
Bill Burmeister | | | | | Joined: Feb 2006 Posts: 150 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 150 | Thanks for the feedback, I need to just cool my heels. I really don't want 6 lug wheels, because the "Grand Plan" is 5 on 4.75 all the way around. It's just these later model wheels look good and are attactively priced and would look good until I change everything to 5 on 4.75. | | |
