| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 81 | I posted a question in the General Forum about '47's having a 5 window model. I got a response that said they did make a 5 window model for 1947.
My question now is how hard would it be to put the corner windows in a 3 window model???? I've got a '52 5 window 1/2 ton cab that is in rough shape but the top and corner's are fine. Can just the corner's be cut out and installed, or do you have to put the entire top on?? I really don't know what I'm doing but I've got a buddy that does good work.
Martin | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | This guy has what you want to know. Beautiful work on the conversion. http://community.webshots.com/user/WallyBody?vhost=communityareI used his photos to cut the old cab and split the inner and outer parts of the corner windows. If a picture is worth a 1000 words this guy has said it all. Neil | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | On one hand it looks like a lot of work, but I think it is a lot easier than attempts I have seen at splitting the cab at the belt. Everyone I know that tried the latter ran into all kind of alignment problems. Using this method is only a question of doing good body work, not dealing with door and windshield alignments. | | | | | Joined: Feb 2008 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 81 | Thanks for your responses. I think I'll try just putting in the windows instead of the whole top.
Thanks again,
Martin | | | | | Joined: Feb 2008 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 81 | Well, we got the cab back from the sandblaster and have one hole cut for the corner window. We are making progress with the conversion from a 3 window to a 5 window. I've posted some more pictures of the '47.
Martin | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | That looks like it is working out pretty good. I was looking at just cutting out the hole for the window and leaving the door jamb and rear window uncut. I am very interested to see how the final job turns out. It looks like your approach would be an easy fit.
Neil | | | | | Joined: Nov 2007 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 80 | Gratifying to see that you have benefitted from my post of the pictures. It looks like you're doing an excellent job so far. One question, what welding method did you use to install? I welded mine with a Lenco Panelspotter> | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i have way to much invested in my truck to do that but i thought about it all the time i was doing the ovehaul.. it makes it so much easier to back up especially into traffic areas. good going. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Feb 2008 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 81 | Hello Wally, Thanks so much for your help with this project. Your post are very much appreciated. As far as the welding, we just used a lincoln mig welder and tacked the outside piece then the inside piece. Sounds like what you used is a sweet method but we didn't have it available. We just went real slow as to not cause any more warping than necessary. We've completed the welding process on the first window and are working on the second. I'll post some more pic soon. Thanks again. Martin | | | | | Joined: Feb 2008 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 81 | I've posted new pictures to my '47 1/2 ton thriftmaster. Got the corner window hole cut and have the Mr. Goodwrench 350 installed. Things are starting take shape. See things at: http://community.webshots.com/user/cowboycpaThanks, Martin | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Martin, Lookin good! Youll love the extra windows when you are done. Tim | | |
