7 members (greenie-reddy, klhansen, carbking, Mike B, Hotrod Lincoln, cmayna, Woodcmiami),
60
Mod | | | Forums66 Topics128,030 Posts1,055,421 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | I am picking up a 1948 Chevy coupe in mid-July and am thinking of going with either a 235 or 250 Chevy Six, or perhaps one of the big GMC Sixes, just to be different!
I know the 235 and the 250 are pretty similar across the board, but how do the larger GMC engines compare in physical size to the 235/250 engines? Is engine mounting the same, or different? Would this go in a '48 coupe without major drama? I'm wanting to run a 700R4 O/D transmission. The original 216 is gone, as is the 3-speed transmission, so I have a big, empty engine bay to start with!
I'm going for the "traditional"/rat look - it's going to be low-buck, yet comfy and safe with lots of old-skool flavor. I love the sounds of a big Six with headers and dual exhausts!
Any ideas?
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | GMC 270 or 302 was the old fix for horsepower back when. THe GMC is only 1 1/2 inches longer than the 216 and bolts up to the old Chev bellhousing, front mount will need to be modified. For the automatic trans and the GMC/Chevy 235s you will need an adaptor, avialable from Langdon's or Buffalo Ent. If you use a 250/292 type motor it bolts right up to the automatic trans but you will have to pick up some side motor mounts also avail. from Langdon's. I have a 47 coupe and it's great although would be nicer with the automatic. | | | | | Joined: Dec 2007 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 96 | The engine bay in the AD looks bigger than it is, especially without a motor in it. I was given a 292/700R4 for free, bought some mounts from Langdon's, and put it in my 53 3600. I had to cut the firewall to get enough clearance (4.5") between the radiator and water pump pulley. Do not even think you are going to use the mechanical fan, it sits way too low. | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | The classic hot rod treatment for that coupe would be a warmed-over GMC 302, if you can find one. Back when Dad was building flathead Fords for the dirt tracks around middle Tennessee, there were lots of military-surplus 270 GMC's around, and some of them were pretty competitive. Their biggest problem was too much low-end torque causing excessive wheelspin off the turns, but if one ever got hooked up, it was hard to beat. Most of the well-modified engines around Nashville were running astronomical compression ratios, multiple carbs, and an alcohol/peroxide fuel mix, and the babbit-rod Chevy engines just wouldn't stand the strain. The full-pressure GMC's with insert bearings would take a lot more abuse. Jerry
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I've got a 302 GMC I'm getting ready to replace my 261 with. It has a much larger oil pan (8qt) than the 235/261, and is a bit longer, but at least it has a high mounted water pump. At least with GMC's you can still use your original bellhousing, you can't do that with a 250. The radiator needs to be slid slightly forward for clearance or you need an electric fan. You can't shorten the water pump on a GMC, they already are.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Patrick66 Would your 48 be a "business coupe"? I had one when I was in high school. The old 216 gave out (from my cool driving) and I dropped a 55 Olds in it. Those old coupes can look really nice.
~Jim
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Here's the 48 coupe that I'm rodding. I went typical small block and auto with a Nova front and rear. The only reason I'm building this car is for experience in stubbing a car and to practice my metal fabbing. So far I haven't bought a single patch panel for it. The only parts I'll need to buy will be the rear fenders and the fuel tank. Let me know if you need any pointers when you get started, I'm pretty much through the mock up stage and will be doing body work when I get back to it, Scott | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | The car that I am trading for. Pretty solid coupe, minor rust in the floors, a few dings, and a broken door glass. Perfect! 1948 Chevy coupe It is NOT a business coupe, BTW. I've tossed around the idea of putting my '69 440 engine in it, just to confound those at car shows where all you see are SBC engines in cars, regardless of the car make! I think the GMC Six would make a pretty good statement, too!
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Uuuhmmmm, that aint a '48, looks like a '42 to me. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | That is a 1946 grille for sure,guaranteed . 1942 grille trim outer edge came down to the bumper or splash pan area. 1946 has that horizontal bar at the bottom of the grille that covers part of the front fenders.
1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yer right Waldo, 42 grill, the one Scott linked has the 48 grill
Bill | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 1942 and 1947 totally different grille look closely at them.It's a 1946 grille. 1946 chevrolet grille 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | You're right bowtietim, that is a 46' grille. (I even had my glasses on earlier!) After looking at the 48' brochure closer, the rest of the door and hood trim looks 48', the Stylemaster Series, not 47'. (One of these things doesn't look like the other...LOL) http://www.oldcarbrochures.com/main.php?g2_itemId=19280So, a 48' with a 46' grille? Anyway, put a nice 6 cylinder GM truck engine in it to keep our discussion sufficiently trucklike.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Randy your right on the 1948 stylemaster series,looks to be the club coupe.I zoomed in on the front fenders and can see the old outline and bolt holes of the original 1948 grille.The original color looks to be green. I would put a 235 or 261 in this jewel. Nice car patrick66 !! 1948 stylemaster series 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | I'm looking at either a 261 or a 235, ideally, but will consider a 250. One of you guys within 400 miles or so of me has an engine and transmission for sale that is good, right?
I think it'll make a pretty neat car!
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I've got the '55 235 that came out of my 48 and a 250 that came out of the Nova that I robbed the stub from. Interested? Condition of both unknown, Scott | | |
