2 members (2-Ton, 1 invisible), 108 guests, and 2 robots.
Topics128,034
Posts1,055,546
Members48,425
#427088 06/27/2008 3:24 AM
First post so please excuse any goofs. On a 54 with the 235 converted to 12 volt should the coil get hot while attempting (and failing ) to start the engine ? Thanks from the new owner of an old truck
First time I saw this truck I said "That's the one!"
1954 Canadian-built Chev Short Box
Hydra1/2ton #427096 06/27/2008 3:47 AM
Hydra1/2ton,
Welcome to the Stovebolt. On a rig of your vintage that has been converted to 12 volts, there are two options for supplying reduced running voltage to the coil. One option would be to install a 12 volt, internally resisted coil. If this option was used, I don't know why repeated starting attempts would heat it.
Option two would involve a bypass circuit somewhere that supplied full battery voltage during STARTS, but reduced voltage when running. This combination 'might' result in a warm coil if you attempted to start it a whole bunch of times.
The most typical scenario would be running into the house to catch the second half of the Lakers game and leaving the ignition switch ON! The key switch is different than most folks are used to, so this can happen, and this will undoubtedly heat the coil.
Stuart
atomarc #427109 06/27/2008 4:36 AM
jdl Offline
There's the fact that the coil could short out. Does the engine run? If so then disregard that.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #427133 06/27/2008 6:00 AM
Im guilty of leaving the key on, once.
I boiled the insides out and melted the lid on the coil... I was lucky thats as far as it went.
My 1953 Chevrolet
1947.1 Gallery
Hydra1/2ton #427393 06/28/2008 3:41 AM
I may have fried the coil myself by leaving the key on . Thanks for the replies.
