| | | Forums66 Topics128,167 Posts1,057,015 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 41 | Has anyone done this? Any info/advice would be appreciated. Thanks | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Sooner, I'm not an expert but, I just finished grafting a 69 Nova subframe onto my 53 3100. I sure learned alot and I'm probably going to learn alot more before it hits the road. If you haven't checked the tech tips or done a search, please do so. My first thought is that the perfered 71-81 Camaro clip will be to wide for your project. Like I always say its the tale of the tape measure. I would think the S-10 would be a better doner vehicle, and there is a ton of information on this site about it. Just my 2$. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The Camaro would be "WAY" too wide. I don't know a clip that is that narrow you could use other than an import of some vintage. Someone else here might be able to add a bit of wisdom on this subject.
~Jim
| | | | | Joined: Jan 2008 Posts: 227 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 227 | British Columbia.....mmm, try and find a wrecked Jaguar sedan. Don't know how common these are in the States, but as we have learnt here in Oz, they bolt straight in and cost next to nothing. Others we are using are from Mitsubishi 2wd utility's. Double wishbone, disc brake etc. and the right width. In fact most Jap import stuff seems near on the right size to fit earlier trucks.....cause being jap they are naturally smaller than the US stuff. Check out the webshot photo's of the Jag front in my '36. | | | | | Joined: Jun 2008 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 71 | There is one at my brothers house here in Washington that a friend of his fathers parked there until he either fixes it or scraps it.. if your interested in it I'm sure he'd let the car go.. it has not been wrecked.. it just needs paint (BAD) and a transmission -- which the car doesn't appear worth the expense or labor. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I think your 39 and my '40 are same frames. I have a Mustang 2 front end in mine that fits well. All sorts of aftermarket kits available with many options ( coil overs, air bags, etc. ) | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | That Jag steering is on the wrong side. I do know that a Camero front end will not go under a 39 car. I have a friend who put one under his 39 car and it was too wide. He pulled it and cut a few inches out of the middle of it. It went back under fine, but it messed up the geometry of the front end and he has a limited turning radius. Bummer! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jan 2008 Posts: 227 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 227 | Hey Joe.....no not the Hendrix song!
Yep the front end pictured in my web photo's is from Australia, hence the Right hand drive. Many Jaguars were exported throughout America and Europe as Left hand drives, this is why I mentioned this front end to SOONER in the first place. You never know if someone might just have one laying around! You don't ask, you don't get.
P.S......Luv ya truck! | | |
