Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Hotrod Lincoln), 195 guests, and 2 robots.
Topics128,290
Posts1,058,566
Members48,492
Has anyone done this? Any info/advice would be appreciated. Thanks
Y
Y Offline
Sooner, I'm not an expert but, I just finished grafting a 69 Nova subframe onto my 53 3100. I sure learned alot and I'm probably going to learn alot more before it hits the road. If you haven't checked the tech tips or done a search, please do so. My first thought is that the perfered 71-81 Camaro clip will be to wide for your project. Like I always say its the tale of the tape measure. I would think the S-10 would be a better doner vehicle, and there is a ton of information on this site about it. Just my 2$.
The Camaro would be "WAY" too wide. I don't know a clip that is that narrow you could use other than an import of some vintage. Someone else here might be able to add a bit of wisdom on this subject.
~Jim
British Columbia.....mmm, try and find a wrecked Jaguar sedan.
Don't know how common these are in the States, but as we have learnt here in Oz, they bolt straight in and cost next to nothing.
Others we are using are from Mitsubishi 2wd utility's.
Double wishbone, disc brake etc. and the right width.
In fact most Jap import stuff seems near on the right size to fit earlier trucks.....cause being jap they are naturally smaller than the US stuff.
Check out the webshot photo's of the Jag front in my '36.
"It's not a wreck......It's a natural resource!"
Quote-Doc Bob circa 2006
DOCS CLASSIC GARAGE
Specializing in Hot Rods,
Customs & Street Machines.
My pictures at..........
1936 Chev 1/2-Ton Holden Body
confused? http://www.koalanet.com.au/australian-slang.html
There is one at my brothers house here in Washington that a friend of his fathers parked there until he either fixes it or scraps it.. if your interested in it I'm sure he'd let the car go.. it has not been wrecked.. it just needs paint (BAD) and a transmission -- which the car doesn't appear worth the expense or labor.
I think your 39 and my '40 are same frames. I have a Mustang 2 front end in mine that fits well. All sorts of aftermarket kits available with many options ( coil overs, air bags, etc. )
1940 Chevy KC 1/2-Ton
That Jag steering is on the wrong side.
I do know that a Camero front end will not go under a 39 car. I have a friend who put one under his 39 car and it was too wide. He pulled it and cut a few inches out of the middle of it. It went back under fine, but it messed up the geometry of the front end and he has a limited turning radius. Bummer!
Joe eek
Hey Joe.....no not the Hendrix song!
Yep the front end pictured in my web photo's is from Australia, hence the Right hand drive.
Many Jaguars were exported throughout America and Europe as Left hand drives, this is why I mentioned this front end to SOONER in the first place.
You never know if someone might just have one laying around!
You don't ask, you don't get.
P.S......Luv ya truck!
DOCS CLASSIC GARAGE
