1 members (GRNHydra), 161 guests, and 0 robots.
Topics128,101
Posts1,056,182
Members48,436
#425496 06/22/2008 3:36 AM
24601
really sucks!!
After we got farm chores done today (Thanks again Doug!), Mike Roache stopped by and we took the fire truck down to the pond ... and pumped !!!! After a bit of goofing around with the settings on the valves, Mike got her to take suction and PUMP!!!
Thanks again 51Ashton for the stuff -- you'll notice the hard sleeve, float dock, wye gate, 1.5" hose and nozzle all in use here. Totally cool to see the pump finally prove it's 100 percent functional!
We didn't go above 100 psi (much ...)
Tanker 51 ... Ready for Dispatch!!
grin
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Good pics, I'm glad we were able to make it work. That was lots of fun,the trucks worth keeps going up. Now if we can get it to pull from the pond with an empty tank.
Mike
1952 Chevrolet 2-Ton 6400
"Dempsey"
Aw drafting drills my favorite, you know John that drafting is some what a lost art in the fire service. Nice to see you having fun with your rig it is really looking good. cool
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
That looks like fun!
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #425952 06/23/2008 4:31 PM
Authorized Pest
Authorized Pest
Besides all that with the water and all, John and Mike got the biggest kick out of going around saying, "THIS TRUCK SUCKS!!"
John needs a t-shirt with that. grin
Looks like something we'll be doing for Homecoming next year!
Peg
~ Peggy M
1949 Chevrolet 3804
you wont be able to until you get that vacuum line hooked up to the pump in a manner it doesnt get into the engine or get yourself a little 12 volt vacuum pump or a diaphragm pump with inlet and outlet check vavles.it wont be as fast as if it was using engine vacuum. for the time being your just going to have to get a prime using some tank water.
glad to hear everything is working out for you.
all we need now is a "ladder 51" and we have a full service department.
Looks like a blast... grin
I hadn't thought about that show "Emergency" in years...
I have to admit, John, your truck definitely sucks - great!
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
54TOW #426175 06/24/2008 4:57 AM
John,
My American fire truck uses what they called a Barton Vacuum Primer, mounted on the fire wall. It's a sorta kidney-shaped beast, one larger float chamber beneath a second, smaller chamber. It's plumbed at the top from manifold vacuum, then to the top side of the pump.
Pull the lever, and vacuum pulls water through the hard suction, into the pump, then into the lower primer chamber. When the float raises enough, a drain opens and the water escapes. If, for some reason, the lower float does not operate, the water goes into the upper chamber, and raises the back-up float, which vents the suction, thereby protecting the engine from ingesting water.
I've always thought these vacuum primers were elegant in their simplicity, not much to malfuntion, and they don't freeze, since they're in the engine compartment. They turn up occasionally on "The Bay", often sold with the fire pump thrown in! ;-)
Other trucks use a large electric motor turning a positive displacement pump to draw the water. Works fine as well. Speaking of which, what happened to your truck's original primer? Had to have one when in service. headscratch
Gotta agree with you, drafting is a blast.
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
Socket Breaker
Socket Breaker
sweet!
-W
Here's my old 1941 Chevy fire truck from Rio Vista CA, Montezums Fire District. I got her as is from a retire farmer who was ready to send her to the crucher before I rescued her at once.
Now I have to find her a new home cause I cant keep any more trucks on my lot. Out of room and rent for out side space is killing me each year.
Look over these and tell me what you guys think I can get for her.
I dnt know how to add pix here, so I will create a folder w/ Flickr and edit a link into this post later. If I forget , just look for them under my Flickr name, fleetwood601964.
EDIT: http://www.flickr.com/photos/26791669@N04/sets/72157605725096298/
SS-427 #426762 06/26/2008 3:52 AM
From these photos, that truck looks VERY restorable, speaking as someone who's working on one a lot like it currently.
From the fire engine side of things, I can tell you that these years of Chevys (Art Deco) don't show up NEARLY as often as the next body style (Advance Design), making them more rare, ergo, to my way of thinking anyway, more valuable.
Also, I think as the collectable car hobby gets more and more INSANE, people will (are) looking with more interest at trucks, and firetrucks are always popular.
Not to mention, there are fewer and fewer out there - hate to see another one get away.
Other opinions?
-Michael
Mikestem #426824 06/26/2008 11:27 AM
V
V Offline
I agree with Mike...
SS-427,
I sent you a private message about fire engine clubs in CA., which might be good to contact. Check your "My Stuff" menu when you are logged in to see if it's there.
-Michael
