Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (3B, Gdads51, Otto Skorzeny, 1 invisible), 93 guests, and 4 robots.
Topics128,281
Posts1,058,472
Members48,490
I have a few questions about 292's for you guys. 1. About how many rpm's could a well build 292 handle?
2. Would it be possible to take it up to 5500 religiously?
3. Does the 292 have 6 ports for intake and 6 for exhaust?
I'm asking this because I might eventually think about building a FI 292 with a single (or dual) turbo setup. Just for fun, of course grin
Drew
55 2 dr 210- after college project
56 2 dr 210- after '55 project
"D'oh"
1.the 292 would handel 5500 rpm if had all proper hipower parts (such as forged piston high performnce conecting rod etc)
2.
thay do not have 12 ports
thay have 6
one for each two cylinders
there is 12 port heads but thay are spendy and hard to find. whith twin turbos you would not need 12 ports
I wonce had the same idea about 250 six I picked the 250 becuse of the higher rpm and qicker revs
I have herd of 250 taking 7000 rpm whith out exploding allthou I would be the last one to try it
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
oldchevy46 is correct, except for one thing...
The GM 292 factory head, along with the 230 and 250 inline 6s, is a 9 port head. There are three intake ports and six exhaust ports. Each intake port is shared between two cylinders. And from a performance standpoint if that weren't bad enough a head bolt boss is cast smack dab in the middle of each intake port.
There has been much research and testing done to improve the inlet flow of the stock cylinder head. Everything from an extreme port and polish and larger valves to removing the head bolt boss altogether and replacing it with lump of material which is either expoxied or bolted in to improve flow.
And with lightweight pistons you can safely take a well built, balanced 292 to 5500 rpms with ease.
-ftyler
Cheapest way to improve the flow in the newer sixes is to make a cross flow head using a pair of sbc heads. Get a copy of Santucci's book on Chevy Inline Sixes, he covers all the aspects of rodding these engines.
Fred
52 3600
69 C-10
