0 members (),
162
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 65 | I have a 1951 Chevy 3100. I took out the seat and did the floors with Por 15 put the seats and mats back in and the next day it started raining. The truck had not moved from it's spot. The next day there was about 6 or 7 water puddles about the size of a quarter on the floor? It was alittle wet by the clutch and emergency brake floor area probally the biggest area,a couple of drops between the wheel and the seat, a couple of quarter sized drops on the passenger side floor. There is a couple of paint wear marks on the dash above the clutch area is one and just to the right of the wiper control under the window. When I touch those spots they seem dry but I am thinking that water may run off them and then they air just drys them quickly. Any thoughts would be welcome as always. Thanks | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Is it condensation dripping from low spots on roof / headliner ? | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The best way to find a leak is to jump into the cab with someone on the outside with a garden hose. If you don't see anything leaking, britcon is probably correct about condensation.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | From your description of some of the areas I would say you have a windshield gasket leaking and the water is "running" to spot and then dripping. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | From your description of some of the areas I would say you have a windshield gasket leaking and the water is "running" to spot and then dripping. and how about your cowl vent gasket....and is the drain hose stopped up? | | |
