1 members (DoubleB), 53 guests, and 0 robots.
Topics128,090
Posts1,056,024
Members48,432
TPB
Offline
I have a 1951 Chevy 3100. I took out the seat and did the floors with Por 15 put the seats and mats back in and the next day it started raining. The truck had not moved from it's spot. The next day there was about 6 or 7 water puddles about the size of a quarter on the floor? It was alittle wet by the clutch and emergency brake floor area probally the biggest area,a couple of drops between the wheel and the seat, a couple of quarter sized drops on the passenger side floor. There is a couple of paint wear marks on the dash above the clutch area is one and just to the right of the wiper control under the window. When I touch those spots they seem dry but I am thinking that water may run off them and then they air just drys them quickly. Any thoughts would be welcome as always. Thanks
Is it condensation dripping from low spots on roof / headliner ?
1940 Chevy KC 1/2-Ton
Ex Hall Monitor
Ex Hall Monitor
The best way to find a leak is to jump into the cab with someone on the outside with a garden hose. If you don't see anything leaking, britcon is probably correct about condensation.
From your description of some of the areas I would say you have a windshield gasket leaking and the water is "running" to spot and then dripping.
and how about your cowl vent gasket....and is the drain hose stopped up?
Moderated by  ndkid275, Phak1
