2 members (Gray_Ghost, RoseB),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 7 New Guy | | New Guy Joined: Apr 2008 Posts: 7 | I've just been collecting parts for my '51 chev 5 window and I was starting to wonder, is the cab on mine the same size as a 1/2 ton? Just wondering if parts are interchangable or not, and I might want to go with a 1/2 ton frame and box.
Thanks, Sean | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | cabs are the same from 1/2 ton to large trucks except for cabover. Frames are very different but cab from a larger one will fit it. | | | | | Joined: Apr 2008 Posts: 7 New Guy | | New Guy Joined: Apr 2008 Posts: 7 | Thanks a lot, I was just thinking a 1 ton might be too long to drive around the city in. Especially for my Wife that wants it as hers. This way I don't have to justify parts!!
Sean | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Are the front fender wheel openings a different size on the 1 ton? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Front fenders on a 1 ton are identical to 3/4 and 1/2 ton.
Front fenders on 1.5 and 2 ton are identical. They are bigger than the small truck fenders.
Grigg | | |
