| | | Forums66 Topics128,012 Posts1,055,315 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | Although my truck has done this for almost since the time I put the motor in, I became really annoyed with this problem recently (probably the hot weather making me irritable). Soon after installing my new motor and exhaust system (around 2 and a half years ago), the truck began to "backfire" on deceleration. I am not sure what the problem is. The truck runs great, I have timed it the best that it possibly could be and it doesn't miss a beat when you hit the gas. Every time you let go of the gas and it begins to decelerate it randomly makes loud popping noises out of the exhaust. The specs are as follows 350, 30 over, original 66 heads off the 327, RV cam, 4 barrel Edelbrock, dual-exhaust with 22" glass packs. Is it possible that the glass packs are damaged? I also am considering that there is backpressure on the engine and it is pulling in cooler exhaust and causing backfire on deceleration. Any ideas? Thanks | | | | | Joined: Feb 2004 Posts: 29,743 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,743 | You need some real mufflers. Glasspacks are straight-through design, and it's not uncommon to get a backfire on deceleration, particularly if the mixture is leaning out a little as the throttle is closed on a coasting situation.
I like to use Cadillac mufflers from the mid-70's. The inlet and outlet pipes are both 2 1/2" diameter, and one muffler will handle the volume requirements of a 500 cubic inch engine. Dual pipes with those mufflers installed have virtually no back pressure, and they're QUIET! Jerry
| | | | | Joined: Feb 2008 Posts: 85 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 85 | Sounds like you are running slightly rich on the mix and you are getting unburned fuel through the system that is igniting in the exhaust system. Fairly common with glasspacks as they tend to run a little hotter than a standard muffler. Try backing off on the fuel mix a little and see what happens! Laterz, Gator >|--|~ | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Dual exhaust...glass packs...had the same issue....it was fuel too lean in our case my uncle backed out the Rod B screw an 1/8 of a turn and that's all it took. Them old guys know! T/C Steve | | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | Ok, good to know, I will mess with it and see what happens. Thanks all. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Make sure you don't have an exhaust leak at the manifolds. I use Flowmasters, no packing to set off unburnt exhaust, and they sound great, Scott | | | | | Joined: Apr 2008 Posts: 143 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 143 | Already checked for leaks. Haven't adjusted carb yet though. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Make shure there are no exhaust leaks or vacuum leaks. Richen up the idle mixture adjustments a little & it will cure it. We used to lean the idle way down many years ago to make it do that because it sounded cool. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | Running a lean idle mixture can cause exhaust pop. Late timing can cause it also. Try tinkering with your idle mixture and bump up your timing a little. Exhaust has nothing to do with popping, except that is heard more with loud mufflers. see what happen. | | |
