3 members (Gdads51, Bill Hanlon, klhansen), 96 guests, and 0 robots.
Topics128,052
Posts1,055,738
how do you remove ignition key lock set?
I need to get some keys made.
Regards,
Lindsay
1958 GMC Canadian 9310
More pix on Photobucket
jdl Offline
There's an article in tech tips.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Problem is I do not have a key that fits
Regards,
Lindsay
take the whole ignition switch out and take it to the locksmith, they should be able to pick it and get the cylinder out - if it has to be drilled out you'll need a new one ohwell
jdl Offline
He wants to know how you get it out of the dash, I think.
Jordan D. Long
Photobucket
No ,Trying to figure out how to remove the lock set part.
I'll take the whole thing out
Regards,
Lindsay
jdl Offline
Guess I was wrong.
Jordan D. Long
Photobucket
I lost the key to the parts truck I purchased and I wanted to use the ig switch, so... With my switch inhand, I was able to pick it myself. I have this old worn out Craftmans tool box key that will just about pick anything if you sort of rub it inside on the little do hickies there and keeping pressure on the lock at the same time. Once I had it truned into the on spot i ran a finishing nail down into it.. I may have just gotten lucky...
Good luck, god bless.
Jesus is Lord!
Only through the blood of Jesus are you washed clean of your sins.
Come see us... Dad's Chevy
Our Video
God bless you! Michael..
jdl Offline
Don't know about your truck but my switch is so worn that you can stick any key into it and it will turn on.
Jordan D. Long
Photobucket
That sounds like the key to my 81 Malibu. No teeth at all on it. Will open a lot of GM car doors!
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
