| | | Forums66 Topics128,266 Posts1,058,368 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | how do you remove ignition key lock set? I need to get some keys made. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | There's an article in tech tips. | | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | Problem is I do not have a key that fits | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | take the whole ignition switch out and take it to the locksmith, they should be able to pick it and get the cylinder out - if it has to be drilled out you'll need a new one  Bill | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | He wants to know how you get it out of the dash, I think. | | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | No ,Trying to figure out how to remove the lock set part. I'll take the whole thing out Thanks | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | | | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | I lost the key to the parts truck I purchased and I wanted to use the ig switch, so... With my switch inhand, I was able to pick it myself. I have this old worn out Craftmans tool box key that will just about pick anything if you sort of rub it inside on the little do hickies there and keeping pressure on the lock at the same time. Once I had it truned into the on spot i ran a finishing nail down into it.. I may have just gotten lucky...
Good luck, god bless.
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Don't know about your truck but my switch is so worn that you can stick any key into it and it will turn on. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | That sounds like the key to my 81 Malibu. No teeth at all on it. Will open a lot of GM car doors! | | |
