1 members (CuzzFuzz), 101 guests, and 2 robots.
Topics128,136
Posts1,056,425
Members48,441
Howdy:
I've got a '53 3100 with the original 216. It sat for about 25 years. I got the motor running. I initially set it up with a gravity feed fuel system. Well, I rebuilt the fuel pump and the carburetor and it runs GREAT!...once I get it running. The engine WILL NOT start without a little help from some starter fluid. Once it's running it will run forever and pretty smooth. Anybody got any ideas?
Craig
1953 3100 | 1958 3/4-ton NAPCO
im no expert but from what the guys around here have been telling me id check all your connections to make sure they are clean and tight. or timing could be wayyyy off. hmm anyone else have ideas?
EDIT: maybe try pump the gas pedal in real quick, and pull the choke. then try?
Make sure your choke works. The old inlines need it to start, even in the summer months,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
2 Offline
Sounds like you need to replace the pump in the carb. They dry out and don't pump or the check ball is gumed up and stuck.
Take the air cleaner off and look into the carb. It should squirt fuel when you open the throttle. Otherwise your accelerator pump isn't working. Most old inliners started the best with 2 squirts. Most people of my generation who learned to drive were taught to pump the pedal twice before cranking. If your accelerator pump isn't working, and it is going to be difficult to start. And it is very likely that it isn't if it sat 25years. Back when your chev was young, it was common to pour a couple of table spoons of gas in the carb until we got around to rebuilding the carb.
