2 members (mo2cyl, panic),
59
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#42255 12/22/2004 7:52 PM | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | I am doing a slight upgrade restoration on my '50 3100. I have '51 Bendix brakes in front, '59 rear axle and brakes. I am about to order brake lines. I know that there is a difference between '50 and '51 lines and also master cylinder. Should I purchase '50 lines and MC, or '51 lines and MC? What are the difference between the two setups in regard to lines and MC only? Thanks in advance, Steve O | | |
#42256 12/24/2004 9:34 PM | Joined: Oct 2002 Posts: 96 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 96 | I don't know about the specific differences, but you might think about bending your own lines. It's pretty easy to make them look good, and it's pretty cheap for the tools and lines. You just need a tubing bender, cutter and flare tool. | | |
#42257 12/25/2004 1:55 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you are going through the bother of replacing the MC, you might as well convert it to a modern dual one. If you don't want to the original will work just fine, the only differance is (I think) the line connection, which can be converted with brass block parts available from your flaps.
I'm pretty sure that the only differance you need to worry about is how the hoses connect to the wheel cylinders.
#42258 12/26/2004 5:09 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I had original Huck brakes on the front of my '50 and changed them to Bendix last year. Bought SS lines throughout and a new MC (single, not dual). Fun project to say the least. http://community.webshots.com/album/116408338rigyal
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
