1 members (delky), 130 guests, and 3 robots.
Topics128,062
Posts1,055,854
Members48,428
#422462 06/12/2008 7:23 PM
I own a DeWalt DW991 14.4 volt rechargeable drill. If you own one, you know that there is no drill chuck key. The chuck is designed to be tightened or looesened by hand. I have been pleased with the drill, but lately it has become difficult to hold the chuck thru part of the cycle while loosening or tightening the chuck to hold a drill bit or a screw driver . I've sprayed it with silicone and applied some light oil. That has helped somewhat, but the chuck is still difficult to hold the chuck with your hand thru the entire tightening or loosening cycle.
Anybody else have this problem? Any solutions?
Joe ohwell
Sometimes... Aleve usually fixes it!!!
~Gator
Thank you, Gator! Baah-dah-bip, Baah-dah-boom!
Joe grin
When all else fails read the instructions. They tell you not to run the motor to tighten or loosen the chuck. Maybe years of doing that has worn the chuck out. Might be time for a new one. Be sure to remove the cap screw holding the chuck to the gun. I broke mine. (Should have read the instructions.)
well your chuck is done ..mine is also ..i use a pair of channell locks to get a grip on it an it still works to this day cant say that abought the batteries ..im down to abought 6 holes per batt.and the batts cost more than the drill to replace ..go figure...but a new chuck will fix your prob.
1952 Chevy Shortbed
Photos in Photobucket
Ex Hall Monitor
Ex Hall Monitor
Read and follow the instructions. What a novel concept. grin You don't suppose it'll catch on do you? dang
dewalts batterys are junk
Stick with the DeWalt.I used to use a Craftsman,then bought a DeWalt,man what a difference.Course the DeWalt is an 18 volt,and it cost quite a bit,but it was worth the extra money.And yeah thats a novel idea,who woulda thought to read the instructions?
Moderated by  MNSmith
