3 members (cmayna, TUTS 59, 1 invisible),
146
Mod | | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I own a DeWalt DW991 14.4 volt rechargeable drill. If you own one, you know that there is no drill chuck key. The chuck is designed to be tightened or looesened by hand. I have been pleased with the drill, but lately it has become difficult to hold the chuck thru part of the cycle while loosening or tightening the chuck to hold a drill bit or a screw driver . I've sprayed it with silicone and applied some light oil. That has helped somewhat, but the chuck is still difficult to hold the chuck with your hand thru the entire tightening or loosening cycle. Anybody else have this problem? Any solutions? Thanks, Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Feb 2008 Posts: 85 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 85 | Sometimes... Aleve usually fixes it!!! ~Gator | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Thank you, Gator! Baah-dah-bip, Baah-dah-boom! Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | When all else fails read the instructions. They tell you not to run the motor to tighten or loosen the chuck. Maybe years of doing that has worn the chuck out. Might be time for a new one. Be sure to remove the cap screw holding the chuck to the gun. I broke mine. (Should have read the instructions.) | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | well your chuck is done ..mine is also ..i use a pair of channell locks to get a grip on it an it still works to this day cant say that abought the batteries ..im down to abought 6 holes per batt.and the batts cost more than the drill to replace ..go figure...but a new chuck will fix your prob. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Read and follow the instructions. What a novel concept.  You don't suppose it'll catch on do you?
| | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | dewalts batterys are junk | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Stick with the DeWalt.I used to use a Craftsman,then bought a DeWalt,man what a difference.Course the DeWalt is an 18 volt,and it cost quite a bit,but it was worth the extra money.And yeah thats a novel idea,who woulda thought to read the instructions? | | |
