8 members (JoeDude, dt235sd, Peggy M, Hotrod Lincoln, Perro, 48jim1ton, Shaffer's1950, 1 invisible),
72
Mod | | | Forums66 Topics128,032 Posts1,055,516 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I hope someone can point me in the right direction. I thinking of putting an S-10 rear axle under my 3100 with open drive line and I know that the old drive "u-joint" doesn't fit. Will I have to make up a driveline to fit the newer differential or can I change the "yoke" to fit my old drive line? Thanks, in advance. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I'm not entirely sure about this one as far as sizes etc. I do know that http://www.summitracing.com/ do conversion U.J's Take some careful measurements and give their site a visit.You might find something that'll work. I've used one on my A.D to connect a 'Vette shaft to a Pontiac rear end. Works a treat!  Good luck. Jock.  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jun 2008 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 71 | NW Drivelines will have it or make it. Go get their phone number and give them a call. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | these places can do about anything.start calling around local and see what you can turn up.i used american driveline in dayton ohio.i didnt have anything.was going to go to a junkyard to buy a shaft to start with ,they told not to worry they had scrap shafts.took my info told me how to measure started with a used shaft with correct yoke,cut it,welded the correct end on it ,balanced it and new u joints for $120.00 all i had to do was go pick it up.was real pleased.............dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Jun 2008 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 71 | david dyehouse knows whats up. | | | | | Joined: Jul 2000 Posts: 620 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 620 | Your talking 4X4 S10 pickup or blazer axle right? As the 2wd Rears are too narrow. | | |
