1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#422304 06/12/2008 5:30 AM
Y
Y Offline
I hope someone can point me in the right direction. I thinking of putting an S-10 rear axle under my 3100 with open drive line and I know that the old drive "u-joint" doesn't fit. Will I have to make up a driveline to fit the newer differential or can I change the "yoke" to fit my old drive line? Thanks, in advance.
I'm not entirely sure about this one as far as sizes etc.
I do know that http://www.summitracing.com/ do conversion U.J's
Take some careful measurements and give their site a visit.You might find something that'll work. I've used one on my A.D to connect a 'Vette shaft to a Pontiac rear end. Works a treat! thumbs_up
Good luck.
Jock. grin
More pix on Flickr.
NW Drivelines will have it or make it. Go get their phone number and give them a call.
these places can do about anything.start calling around local and see what you can turn up.i used american driveline in dayton ohio.i didnt have anything.was going to go to a junkyard to buy a shaft to start with ,they told not to worry they had scrap shafts.took my info told me how to measure started with a used shaft with correct yoke,cut it,welded the correct end on it ,balanced it and new u joints for $120.00 all i had to do was go pick it up.was real pleased.............dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
david dyehouse knows whats up.
"MONGO"
"MONGO"
Your talking 4X4 S10 pickup or blazer axle right? As the 2wd Rears are too narrow.
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
