4 members (Otto Skorzeny, SNOYL, Wayne67vert, Barry Martak), 101 guests, and 3 robots.
Topics128,096
Posts1,056,482
Members48,444
A person on a 36 Chevy Owners site I also belong to inquired about contacting someone in OR or WA who was making a special intake to adapt Corvair turbo to an inline Chevy. Anyone have knowledge of who this is and contact information? Thanks.
bump!
This topic is too interesting to slip away unnoticed.
intake? why would a special intake manifold be needed? do you mean exhaust manifold?
You don't even need a special exhaust manifold just pick the appropriate size turbo for the cubic inch displacement of the engine and waste gate for the boost you want to run. Pick a place to mount it that will allow ease of plumbing and go to work adding intake and exhaust tubing.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
You know, this very thing pops into my head every time I go to the Hoosier Swap Meet! They have a decent turn out of guys with'Vair parts, I always seem to fing at least 1 turbo for those, and usually more than that. They look to be about right for a 235, I've actually considered running 2 on mine, one for each carb/header.
Bill Burmeister
you'd likely be better off with a single small turbo rather than two for a low RPM motor like an L6
I'll probably never actually never do it. It's really more just a case of "Hmm, I wonder if that'll work? " kind of thing.
Bill Burmeister
Better invest in a couple of big tubs to haul the engine pieces home after that installation! Take a good look at the crankshaft, main bearings, and connecting rods berfore you start adding the stress of a turbo to that bottom end. The 216/235/261 engines don't have enough main bearings to resist some serious crankshaft twisting, and the con rods are way too flimsy to take much turbo boost. Now, a 292 with a good set of billet rods would be an entirely different story!
