2 members (VicZ, klhansen),
118
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 55 | A person on a 36 Chevy Owners site I also belong to inquired about contacting someone in OR or WA who was making a special intake to adapt Corvair turbo to an inline Chevy. Anyone have knowledge of who this is and contact information? Thanks. Jerry | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | bump!
This topic is too interesting to slip away unnoticed. | | | | | Joined: Jun 2008 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 71 | intake? why would a special intake manifold be needed? do you mean exhaust manifold?
| | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | You don't even need a special exhaust manifold just pick the appropriate size turbo for the cubic inch displacement of the engine and waste gate for the boost you want to run. Pick a place to mount it that will allow ease of plumbing and go to work adding intake and exhaust tubing. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You know, this very thing pops into my head every time I go to the Hoosier Swap Meet! They have a decent turn out of guys with'Vair parts, I always seem to fing at least 1 turbo for those, and usually more than that. They look to be about right for a 235, I've actually considered running 2 on mine, one for each carb/header.
Bill Burmeister | | | | | Joined: Jun 2008 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2008 Posts: 71 | you'd likely be better off with a single small turbo rather than two for a low RPM motor like an L6 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I'll probably never actually never do it. It's really more just a case of "Hmm, I wonder if that'll work? " kind of thing.
Bill Burmeister | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Better invest in a couple of big tubs to haul the engine pieces home after that installation! Take a good look at the crankshaft, main bearings, and connecting rods berfore you start adding the stress of a turbo to that bottom end. The 216/235/261 engines don't have enough main bearings to resist some serious crankshaft twisting, and the con rods are way too flimsy to take much turbo boost. Now, a 292 with a good set of billet rods would be an entirely different story! Jerry
