8 members (49nut, HandyAndy, Wally / Montana, cmayna, Hotrod Lincoln, GRNHydra, Leo, 1 invisible),
146
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,087 Posts1,055,980 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 45 New Guy | | New Guy Joined: Dec 2005 Posts: 45 | Need some help locating a combination brake pedal, clutch pedal that is firewall mount. Saw one but don't remember where. | | | | | Joined: Feb 2004 Posts: 29,783 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,783 | Try the JEGS catalog. They have brake and clutch pedal assemblies, and the master cylinders that work with them. Be absolutely sure to build in enough bracing that the firewall doesn't flex and crack under pedal pressure. Been there, done that, on round track race cars! Jerry
| | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | I'm using S10 pedals and the stock steering column. I ran the two support rods back to the mounting holes for the steering and one goes right through all the layers. The other is it's own hole.
I got the power brake booster and the pedals for like $25 at a local yard.
This is on an AD truck.
I've got a set from a Nissan as well but I haven't mounted them. They were $20 complete. Slave cyl, master cyl, and mounting holes.
I may eventually extend the pedals a bit but I don't think they are that far off the floor that I'm going to sweat it. Once she's a runner, I'll let you know!! | | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | Oh, if you manage to get it from an S10, make a template of the holes in the firewall so you know where to drill! | | |
