1 members (carbking), 103 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#4209 08/04/2002 5:51 PM
What is a 283 worth? I have a trusted friend with a 283 sitting on his garage floor. The story is, a friend of his was changing motors and he got the 283. He went to the guys house and the guy started it up, he said it ran well. The guy shut it off and took it out. It has been sitting for 10 or 12 years, covered in a heated, dry garage. It has oil pan, carb. and dist., plugs and plug wires still attached. As some of you know I am new to this motor stuff, so Im' asking you for a ballpark $$ on it's worth. I want to put it in my '55 first series.
Thanks, Buddy in AK
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
#4210 08/04/2002 7:19 PM
If it is a running rebuilder, I would venture to say around $150 to $300,maybe a little more if it runs really well.
If it has a starter on it, you can get the oil system primed and then crank the engine over to get a compression reading.That can tell you a lot even though it will be a cold test as compared to a warmed up running test.
#4211 08/04/2002 10:59 PM
Unless he pickled it by running it out of gas, then oiled the cylinders and cranked it to lube the cylinder walls, the walls will probably be rusty. Go visit your proctologist, steal his scope, and look inside the cylinders! grin
Fred
52 3600
69 C-10
#4212 08/06/2002 7:47 AM
Did you hear about the proctologist who wanted to become a mechanic?
He went to school for automotive mechanics.The instructor gave the class an assignment with 100 points possible for taking an engine apart(50pts) and putting it back together(50pts).When the proctologist got his test score back he saw he had 150 pts.He asked the instructor how he got 150pts when there were only 100pts possible? the instructor replied;I gave you 50pts for taking the engine apart,50pts for putting the engine back together and 50pts for doing it all through the tail-pipe eek
#4213 08/06/2002 1:05 PM
i just sod a 283 long block freah out of machine shop not assembled for 500.oo less intake/carb and dist .all new parts hope this will help .
47 Chevy COE..52 TO 30
#4214 08/07/2002 7:06 PM
Thanks Guys..............
Buddy in AK
'50 GMC Suburban
