| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | What is a 283 worth? I have a trusted friend with a 283 sitting on his garage floor. The story is, a friend of his was changing motors and he got the 283. He went to the guys house and the guy started it up, he said it ran well. The guy shut it off and took it out. It has been sitting for 10 or 12 years, covered in a heated, dry garage. It has oil pan, carb. and dist., plugs and plug wires still attached. As some of you know I am new to this motor stuff, so Im' asking you for a ballpark $$ on it's worth. I want to put it in my '55 first series. Thanks, Buddy in AK | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | If it is a running rebuilder, I would venture to say around $150 to $300,maybe a little more if it runs really well. . If it has a starter on it, you can get the oil system primed and then crank the engine over to get a compression reading.That can tell you a lot even though it will be a cold test as compared to a warmed up running test.
#4211 08/04/2002 10:59 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Unless he pickled it by running it out of gas, then oiled the cylinders and cranked it to lube the cylinder walls, the walls will probably be rusty. Go visit your proctologist, steal his scope, and look inside the cylinders!
Fred 52 3600 69 C-10
| | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Did you hear about the proctologist who wanted to become a mechanic? He went to school for automotive mechanics.The instructor gave the class an assignment with 100 points possible for taking an engine apart(50pts) and putting it back together(50pts).When the proctologist got his test score back he saw he had 150 pts.He asked the instructor how he got 150pts when there were only 100pts possible? the instructor replied;I gave you 50pts for taking the engine apart,50pts for putting the engine back together and 50pts for doing it all through the tail-pipe
| | | | | Joined: Apr 2001 Posts: 39 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 39 | i just sod a 283 long block freah out of machine shop not assembled for 500.oo less intake/carb and dist .all new parts hope this will help .
47 Chevy COE..52 TO 30
| | | | | Joined: Sep 2001 Posts: 466 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 466 | Thanks Guys.............. Buddy in AK | | |
