6 members (Hotrod Lincoln, Peggy M, klhansen, IHPWR, DadsFirstPickup, 49choptop), 87 guests, and 1 robot.
Topics128,043
Posts1,055,605
#419169 06/02/2008 7:21 PM
my truck started and ran about a year or two ago, and it sat outside frown hasnt been started ever since.
well i got a new battery, and put some gas in it and it turned over, but sounds pretty slow. it wont start and im wondering what i can do to help her start.
I
I Offline
Fuel injector/ carb cleaner into the full tank of high octane gas. Pull the plugs and clean them. Check the distibutor cap and rotor clean off the points where the rotor hits as it spins. Clean the air filter or replace. Replace fuel filter. Theres more but thats basic. Sounds like it needs to have a good run,...idle it a bit high for 10 minutes to get all that carbon and varnish out of there. Check your rad fluid and oil levels before you start her up again. If ya can get her on the highway,...HAMMER DOWN BABY!!! woohooo!!! and get that snot out of her from sitting. Say,...wake up! get up! whos your frikken Daddy!!? Works for me everytime !....lol. Good luck,...I,ll keep an eye on this post to see how all is doing. Cheerz.
hahahaha sounds good, ill start with that and post the happenings of that. thanks for the good laugh by the way.
i have new plugs that were left in the truck when we got it, they are ACdelco .r43. what is the difference between then and the ones that were already being used which say AC 44?
Riding in the Passing Lane
Very little difference. The 44 is one range hotter. The prefix R means they have resisters for radio suppression.
1972 Chevy c10 Cheyenne Super
so can i use the r43's??
sorry if this is obvious.
43's are too cold and will foul quickly. 43's were for heavy duty, that is a truck that was used to the max. Be sure to drain the gas and put in fresh gas. Stale gas causes valves to stick and that can lead to really horrible things. Clean your battery cable ends on both ends. At the battery and starter and the frame as well.
jdl Offline
Might get some starting fluid. That helped mine when I started it for the first time. Just be sure to not overuse the starting fluid, from what I'm told it can blow the head off of your block.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #419347 06/03/2008 3:49 AM
jdl Offline
Oh, duh, silly me, get your coil/sparkplug wire problems sorted out!
Jordan D. Long
Photobucket
jdl #419351 06/03/2008 4:03 AM
yes,,
sprayed some carb cleaner in there and no luck so its defenatly sparking problem
i took off the ignition coil and there was alot of junk deposit at the bottom, where the sparkplug wire attaches, so i cleaned it so tomorrow ill try it out. if not, ill go and see about a new 6volt coil at the local auto part store, they seem pretty cheap at american classic.
after cleaning the coil, still no luck
i also charged the battery becuse it was dead, and it turns over but doesnt fire.
poured a LITTLE gas straight into the carb but STILL nothing.
any help guys?
jdl Offline
It still sounds like your coil is bad, there's spark in the points, and your wires are new, right? So it almost has to be your coil.
Jordan D. Long
Photobucket
#420633 06/07/2008 12:52 AM
toomany2count,
i pulled them apart when the battery was connected, and it sparks when i pull them apart.
i also took a timing light, and attached it to the MIDDLE WIRE attaching to the coil, and when we cranked the engine, it flashed.
when we tried it on the other wires, no light flashed from the gun.
so why am i not getting the spark to go to the plugs... the wires are all brand new.and in the right order.
thanks!!
#420636 06/07/2008 1:16 AM
where is the ground strap on the points?
i can tell you the previous owner had the starter wired good, and when he droped it off in our yard, it started and ran good. this was about a year ago
we havent messed with it since.
sorry im trying not to frustrate you, im new to this and am only 15 years old.
#420637 06/07/2008 1:16 AM
jdl Offline
Ground strap on the points?
Jordan D. Long
Photobucket
jdl #420640 06/07/2008 1:21 AM
the battery seems not to be cranking the engine fast enough to get her started.
how fast should it be turning over?
#420662 06/07/2008 2:19 AM
well,
I GOT HER STARTEDDD!!! haha it was great!!
well to tell you how stupid the fix was, we pulled up on the metal part on top of the roter, and then flipped the cap the other way and she sputtered to life!!
now, we are off to the brakes!!
thanks for all the advice guys!!!
#422220 06/12/2008 12:52 AM
well i went to start the truck, and it would turn over fast but it wouldnt sputter or try to start.
ive done all of the advice toomany2count has given me, but no luck
there isnt any spark, so should i go to my flaps and get new points/coil/condencer?
it started and ran 2 days ago, so im wondering what could have gone wrong.
any help would be deeply appriciated.
jdl Offline
Do you still have spark at the points? The only thing I can think of is if something burnt up when you started it the other day. If you don't have any spark at the points, get some new points(they should probably be replaced anyway) and a condenser. If you do, then that means that the condenser is fine because it is what stores the spark for the points. If that checks out, then it might be your coil.
Jordan D. Long
Photobucket
jdl #422236 06/12/2008 1:33 AM
alright well tomorrow ill se about getting new points and condencer and see how that goes
thanks jdl
jdl Offline
You're welcome.
Jordan D. Long
Photobucket
