2 members (55shaker, Otto Skorzeny), 68 guests, and 2 robots.
Topics128,026
Posts1,055,403
Members48,422
#419786 06/04/2008 1:53 PM
Whats the best way to grease a throw-out bearing on a three speed tranny on a 54 chevy half-ton? I have looked but not really found a grease fitting-thanks
bolted54,
These bearings are sealed with a factory pack and don't require any servicing. When they howl and scream, it's usually time for a whole clutch/pressure plate redo, at which time you stick in a brand new throwout bearing.
Stuart
Stuart said it ...yup a new bearing is best.
1952 Chevy Shortbed
Photos in Photobucket
I go with "put in a new bearing." And replacement of the clutch/pressure plate while you are there. Saves time.
That is best.
Dennis
atomarc #419976 06/05/2008 12:03 AM
so with a series 1 enclosed drive shaft I am gonna have to pull the whole rear end just to do this? Because if so I am just gonna fry it till I get a new rear end and t5-Its not a bad howl it just whines when I engage the clutch.
bolted54,
To R&R the transmission for clutch work, you don't have to actually pull the rear end/drive line, you just disconnect it at the u-joint and drop it down.
A noisy throwout bearing can last a very long time. If you have future plans I think I would agree with you...just wait!
Stuart
