7 members (JW51, TUTS 59, 3800GUY, Otto Skorzeny, cmayna, 52GMC35424JD, 1 invisible),
105
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 66 | Whats the best way to grease a throw-out bearing on a three speed tranny on a 54 chevy half-ton? I have looked but not really found a grease fitting-thanks | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | bolted54,
These bearings are sealed with a factory pack and don't require any servicing. When they howl and scream, it's usually time for a whole clutch/pressure plate redo, at which time you stick in a brand new throwout bearing.
Stuart | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Stuart said it ...yup a new bearing is best. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I go with "put in a new bearing." And replacement of the clutch/pressure plate while you are there. Saves time.
That is best.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: May 2008 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 66 | so with a series 1 enclosed drive shaft I am gonna have to pull the whole rear end just to do this? Because if so I am just gonna fry it till I get a new rear end and t5-Its not a bad howl it just whines when I engage the clutch.
To R&R the transmission for clutch work, you don't have to actually pull the rear end/drive line, you just disconnect it at the u-joint and drop it down.
A noisy throwout bearing can last a very long time. If you have future plans I think I would agree with you...just wait!
Stuart | | |
