2 members (Ponchogl, Hush), 67 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#418029 05/29/2008 10:57 PM
I have put new dynacorn metal front fenders and inner fenders in my 53 3100, as well as a new grille. The hood is over lapping the fenders. If I shim the fenders out from the core support to close the hood then the fenders are to far apart for the grille.Can anyone help? Is there a secret to adjusting the hood ?Anyone PLEASE this truck is about to send me over the edge.
Popa Kents Body Shop
popa #418192 05/30/2008 1:08 PM
popa,
hows your gap at the back of the hood against the cowl?.. can you move the hood back more is what I am asking?
1952 Chevy Shortbed
Photos in Photobucket
Ex Hall Monitor
Ex Hall Monitor
If the hood is original your description sounds like the fenders aren't correct. Without being there to see the problem my guess is you'll need to section the hood to narrow it which is a LOT of work. The preferred alternative would be to return the ill fitting fenders and locate used OEM fenders which should fit much better.
Tiny #418791 06/01/2008 3:55 PM
Thanks for your replies. I received some info from an old shop manual that I hope will help.
popa #419392 06/03/2008 6:39 AM
The factory fit is hit and miss on these trucks, so sometimes the replacement panels fit well and sometimes they don't. At the factory they just picked whatever panels fit best from a pile and left it alone. There is a lot of variability, especially in the doors and cab.
Paint & Body Shop moderator
I agree with 4ontheFloor..my hood and fenders are factory and they fit ..well SO SO...Ive tweaked em as far as the factory holes will allow and I still have a fit that could be a lot better ...but that is how they were made so I am just livin with it as is.
Tim
1952 Chevy Shortbed
