| | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 44 | I have put new dynacorn metal front fenders and inner fenders in my 53 3100, as well as a new grille. The hood is over lapping the fenders. If I shim the fenders out from the core support to close the hood then the fenders are to far apart for the grille.Can anyone help? Is there a secret to adjusting the hood ?Anyone PLEASE this truck is about to send me over the edge.
Popa Kents Body Shop
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | popa, hows your gap at the back of the hood against the cowl?.. can you move the hood back more is what I am asking? | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | If the hood is original your description sounds like the fenders aren't correct. Without being there to see the problem my guess is you'll need to section the hood to narrow it which is a LOT of work. The preferred alternative would be to return the ill fitting fenders and locate used OEM fenders which should fit much better.
| | | | | Joined: Jul 2006 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 44 | Thanks for your replies. I received some info from an old shop manual that I hope will help.
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The factory fit is hit and miss on these trucks, so sometimes the replacement panels fit well and sometimes they don't. At the factory they just picked whatever panels fit best from a pile and left it alone. There is a lot of variability, especially in the doors and cab.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I agree with 4ontheFloor..my hood and fenders are factory and they fit ..well SO SO...Ive tweaked em as far as the factory holes will allow and I still have a fit that could be a lot better ...but that is how they were made so I am just livin with it as is. Tim | | |
