0 members (),
84
Mod | | | Forums66 Topics128,290 Posts1,058,566 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 35 | I have searched and searched the forums on dropping, converting to front disc brakes AND swapping out the IFS on a 1966 Suburban. I can not find much on the forums on doing this.
Basically wanting the least expensive way of lowering my Burb, and have disc brakes on it too. I have more time than I have money.
Thought I could swap out the IFS to a later model in order to get the disc brakes off of it. Than drop it using drop spindles.
Anyone know of this process and the least expensive way of doing this. I would like to hear from you. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The IFS used '63 through '87 on pickups and a few years longer on Blazers and Suburbans is the same basic design. Depending on exactly what years you are dealing with some holes may need to be enlarged, but its basically a bolt in swap.
Starting in 1971 disk brakes were available, so all you need do is find a '71 or later and swap the complete crossmember with suspension. I'd subbest looking for one with power steering and swapping that too.
You can find these things nearly free, so establish a budget and look for the one in best condition that you can afford. Remember even the newest ones are nearly 20 years old and likely to need ball joints and bushings.
If you could find one in a wrecking yard that already had dropped spindles that could be your best bet for doing this on the cheap, though the drop spindles aren't real expensive.
If you have more time than money I'd suggest spending time finding good parts cheap.
The disk brake trucks are all 5-lug, so you are either going to change the rear also, so have both 5- and 6-lug wheels going this route.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The 80's power steering pump might mount off the head. If that's the case it won't mount on a '66 motor. Either you need an earlier pump (at least the brackets) or later heads.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2005 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 35 | I have found out the truck I got all this off of is a 73-80 model. Plus I am rebuiling a 350 and putting it in the 66 Burb. Thanks for the advice. Next I will be doing the power booster. Any advice here??? What works best? I am looking for a booster that is not very big but will do the job of stopping this truck. How do you hook one up - never done this work before. I am also installing the power steering box. Seems easy so far. Just put in some spacers and grind off the old steering joint and than attach it to the newer style that bolts on. (Just check out the pics up above, or here are the links again.) Here are pics of the new disc brakes going in: http://i270.photobucket.com/albums/jj120/Chevanman/1966%20Chevy%20Suburban/IFSswap1980to1987pic2.jpgI used a trans jack for this and it worked great! http://i270.photobucket.com/albums/jj120/Chevanman/1966%20Chevy%20Suburban/IFSswap1980to1987pic1.jpgIt is now bolted in after doing the drilling.
