4 members (Ponchogl, TUTS 59, Otto Skorzeny, Hotrod Lincoln), 128 guests, and 1 robot.
Topics128,126
Posts1,056,353
Members48,441
Has anyone installed a set of Roller Rockers and Roller Lifters in a 40 chevy 6?
I would be glad to if you can find them! grin
I assume you are talking about a 216 cu-in straight 6? No roller rockers or lifters are made for the 216-235-261 engine family. There were some "Baker hi-lift" rocker arms made in the '50s, but good luck finding a set. But by the time you got to the RPM range where they'd make a differance, pieces of the motor would be flying through the fenders. The '40s era chevy engines will grenade if revved past 3500 RPM on a regular basis.
The 216 is a "splash-oiled" system that uses dippers and nozzles to spray oil at the big end of the conn rods, as there are no oil passages drilled in the crank. This combined with only 4 main bearings, is not the hot ticket for power.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
I have a set of the hi-lift rocker arms. I haven't installed them. Are they really worthless? Will they hurt my 216 under normal use?
Jim
Jim
Jim....Hi lift rockers will give you a bit more torque....that feel like power
Please don't push any 216 hard!
Thanks Proffit. I have one intake rocker that's been making noise and tonight I checked it and its got a thump to it when I touch it running and is rough moving with engine off. I picked up a set of Fenton high lifts a couple of years ago, and figure I might as well use them when I overhaul the rocker assembly tomorrow.
Not for racing, but it is just a bit hilly here in North Georgia... wink
Jim
