1 members (Rich'sToys),
90
Mod | | | Forums66 Topics128,079 Posts1,056,310 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41917 06/06/2002 8:42 AM | Joined: Jun 2002 Posts: 21 Member | | Member Joined: Jun 2002 Posts: 21 | Has anyone installed a set of Roller Rockers and Roller Lifters in a 40 chevy 6? | | |
#41918 06/06/2002 9:07 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | I would be glad to if you can find them!
#41919 06/06/2002 4:08 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | I assume you are talking about a 216 cu-in straight 6? No roller rockers or lifters are made for the 216-235-261 engine family. There were some "Baker hi-lift" rocker arms made in the '50s, but good luck finding a set. But by the time you got to the RPM range where they'd make a differance, pieces of the motor would be flying through the fenders. The '40s era chevy engines will grenade if revved past 3500 RPM on a regular basis.
The 216 is a "splash-oiled" system that uses dippers and nozzles to spray oil at the big end of the conn rods, as there are no oil passages drilled in the crank. This combined with only 4 main bearings, is not the hot ticket for power.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#41920 06/06/2002 6:21 PM | Joined: Sep 2000 Posts: 114 Member | | Member Joined: Sep 2000 Posts: 114 | I have a set of the hi-lift rocker arms. I haven't installed them. Are they really worthless? Will they hurt my 216 under normal use?
Jim
Jim
#41921 06/06/2002 7:13 PM | Joined: Aug 2000 Posts: 523 Member | | Member Joined: Aug 2000 Posts: 523 | Jim....Hi lift rockers will give you a bit more torque....that feel like power Please don't push any 216 hard! | | |
#41922 06/08/2002 3:39 AM | Joined: Sep 2000 Posts: 114 Member | | Member Joined: Sep 2000 Posts: 114 | Thanks Proffit. I have one intake rocker that's been making noise and tonight I checked it and its got a thump to it when I touch it running and is rough moving with engine off. I picked up a set of Fenton high lifts a couple of years ago, and figure I might as well use them when I overhaul the rocker assembly tomorrow. Not for racing, but it is just a bit hilly here in North Georgia...
Jim
