| | | Forums66 Topics128,032 Posts1,055,521 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 67 | my truck started and ran about a year or two ago, and it sat outside  hasnt been started ever since. well i got a new battery, and put some gas in it and it turned over, but sounds pretty slow. it wont start and im wondering what i can do to help her start. | | | | | Joined: Dec 2007 Posts: 166 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 166 | Fuel injector/ carb cleaner into the full tank of high octane gas. Pull the plugs and clean them. Check the distibutor cap and rotor clean off the points where the rotor hits as it spins. Clean the air filter or replace. Replace fuel filter. Theres more but thats basic. Sounds like it needs to have a good run,...idle it a bit high for 10 minutes to get all that carbon and varnish out of there. Check your rad fluid and oil levels before you start her up again. If ya can get her on the highway,...HAMMER DOWN BABY!!! woohooo!!! and get that snot out of her from sitting. Say,...wake up! get up! whos your frikken Daddy!!? Works for me everytime !....lol. Good luck,...I,ll keep an eye on this post to see how all is doing. Cheerz. | | | | | Joined: May 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 67 | hahahaha sounds good, ill start with that and post the happenings of that. thanks for the good laugh by the way. | | | | | Joined: May 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 67 | i have new plugs that were left in the truck when we got it, they are ACdelco .r43. what is the difference between then and the ones that were already being used which say AC 44? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Very little difference. The 44 is one range hotter. The prefix R means they have resisters for radio suppression. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 67 | so can i use the r43's??
sorry if this is obvious. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | 43's are too cold and will foul quickly. 43's were for heavy duty, that is a truck that was used to the max. Be sure to drain the gas and put in fresh gas. Stale gas causes valves to stick and that can lead to really horrible things. Clean your battery cable ends on both ends. At the battery and starter and the frame as well.
| | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Might get some starting fluid. That helped mine when I started it for the first time. Just be sure to not overuse the starting fluid, from what I'm told it can blow the head off of your block. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Oh, duh, silly me, get your coil/sparkplug wire problems sorted out! | | | | | Joined: May 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 67 | yes,, sprayed some carb cleaner in there and no luck so its defenatly sparking problem
i took off the ignition coil and there was alot of junk deposit at the bottom, where the sparkplug wire attaches, so i cleaned it so tomorrow ill try it out. if not, ill go and see about a new 6volt coil at the local auto part store, they seem pretty cheap at american classic.
| | | | | Joined: May 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 67 | after cleaning the coil, still no luck
i also charged the battery becuse it was dead, and it turns over but doesnt fire.
poured a LITTLE gas straight into the carb but STILL nothing.
any help guys? | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | It still sounds like your coil is bad, there's spark in the points, and your wires are new, right? So it almost has to be your coil. | | | | | Joined: May 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 67 | toomany2count,
i pulled them apart when the battery was connected, and it sparks when i pull them apart.
i also took a timing light, and attached it to the MIDDLE WIRE attaching to the coil, and when we cranked the engine, it flashed.
when we tried it on the other wires, no light flashed from the gun.
so why am i not getting the spark to go to the plugs... the wires are all brand new.and in the right order.
thanks!! | | | | | Joined: May 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 67 | where is the ground strap on the points?
i can tell you the previous owner had the starter wired good, and when he droped it off in our yard, it started and ran good. this was about a year ago
we havent messed with it since.
sorry im trying not to frustrate you, im new to this and am only 15 years old.
| | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Ground strap on the points? | | | | | Joined: May 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 67 | the battery seems not to be cranking the engine fast enough to get her started.
how fast should it be turning over? | | | | | Joined: May 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 67 | well,
I GOT HER STARTEDDD!!! haha it was great!!
well to tell you how stupid the fix was, we pulled up on the metal part on top of the roter, and then flipped the cap the other way and she sputtered to life!!
now, we are off to the brakes!!
thanks for all the advice guys!!! | | | | | Joined: May 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 67 | well i went to start the truck, and it would turn over fast but it wouldnt sputter or try to start.
ive done all of the advice toomany2count has given me, but no luck
there isnt any spark, so should i go to my flaps and get new points/coil/condencer?
it started and ran 2 days ago, so im wondering what could have gone wrong.
any help would be deeply appriciated. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Do you still have spark at the points? The only thing I can think of is if something burnt up when you started it the other day. If you don't have any spark at the points, get some new points(they should probably be replaced anyway) and a condenser. If you do, then that means that the condenser is fine because it is what stores the spark for the points. If that checks out, then it might be your coil. | | | | | Joined: May 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 67 | alright well tomorrow ill se about getting new points and condencer and see how that goes
thanks jdl | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | | | |
