1 members (78buckshot),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 41 New Guy | | New Guy Joined: Sep 2007 Posts: 41 | | | | | | Joined: Jan 2007 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 66 | That is a killer sweet truck! Glad you made it back from Iraq in one piece,, thanks for your service!
Jon
| | | | | Joined: Mar 2008 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 61 | Great truck and thanks for your sevice.
Bill S. Tempe, AZ
| | | | | Joined: Sep 2007 Posts: 41 New Guy | | New Guy Joined: Sep 2007 Posts: 41 | Thanks. I tried the VIN decoder thing, and it said that it's a 1962, but I know it's a '47. Do I have the right serial number? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What is the number/code that you have and where did you find the number/code?
Welcome back - thank you for serving.
Tim | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Have you checked the engine number on the pad next to the distributor? Many states registered vehicles by the engine number. I notice that the engine is a later 235. And that is good. Cleon
| | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | It looks like the "Fireball" that someone(can't remember who you said did it, if any) painted on it is coming off. Nice truck though, wish mine looked that good. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | What do the tags/badges on the dash say? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 210W-K 4524 is on the VID plate (where is the plate located)?
It is 1950 or earlier, because it has the driver-side cowl-vent.
Where is the gas tank filler?
Does it have modern-style tube shock absorbers?
These next items might have changed over the years, but they might help identify the year: - What is the color of the knob/handle on the lever that controls the driver-side cowl-vent? - What color is the wiper knob?
| | | | | Joined: Dec 2006 Posts: 165 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 165 | Great looking truck Jared! Glad to have you home, and thank you for your service.
Kevin Kevin
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | That's "21QW", which decifers to, "21" =Janesville, Wis. assembly plant. "QW"= 1947 161"in. wheelbase, 2 ton truck. Other ways of distinguishing the model, are the smooth firewall(no "H" enforcing), larger 5 fuse, fuse box, fuel tank, on the right frame-rail, & pinstripping on the leading edge of the grille bars, which are all '47, & '48 model characteristics. Looks like you have a set of Vintage Marble Reflectors also. Those things are like "Gold", in good condition. Got any pictures of the reflectors. I've got a collection of them myself. Nice truck, & thanks for the pictures. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | I think spanky either has better eyesight or is more observant than a couple of us! | | | | | Joined: Sep 2007 Posts: 41 New Guy | | New Guy Joined: Sep 2007 Posts: 41 | Thanks for your help, especially spanky. those are all the pictures I have, but I can try to get my dad to take some more. That plate is located inside the driver's side door jamb. I'd have to ask if they swapped out a lot of parts, but as far as I know they just ran it till the main bearings went out, then parked it. | | | | | Joined: Sep 2007 Posts: 41 New Guy | | New Guy Joined: Sep 2007 Posts: 41 | Anybody know the best way to fix up the bed? I was thinking about building short sides, tall enough that kids can ride in the back for parades. | | | | | Joined: May 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 67 | i would take all the wood off, and Zero Rust, or POR-15 the metal. then use oak (sealed of course) to make it, and the sides.
this is the plan for mine... | | |
