8 members (Tinker5, Leo, 1955 1 Series, Mike B, Danielbolt, Wally / Montana, Bill Hanlon, 1 invisible), 99 guests, and 1 robot.
Topics128,154
Posts1,056,863
Members48,456
#41781 10/01/2003 10:13 PM
I have been thinking about putting a saginaw four speed in my 51 3100 with 235. The kit is from patricks, the one where you keep the torque tube. THE KIT SELLS FOR $449.95, anyone using it? old navy chief ,wayne
#41782 10/01/2003 11:03 PM
ODSS President
ODSS President
That's a lot of money for ending up with the same final drive (1:1). There is no difference between 3rd gear in a three speed trans. and 4th in a 4 speed trans. With that 4.10 rear you're not going anywhere in a hurry either way.
I would go to LAROKE's wonderful pages to tighten up my 3 speed column shifter for short money, for the long money there are a plethora of ways to make her go from A to B.
Look in the Gallery and email someone who has a truck like yours and ask what they've done, better yet, ask if they could do it over what they would do. Anyway you do it it's your trip and we'll all support you no matter what decision you make.
~ Cosmo
1949 Chevy Half Ton
#41783 10/01/2003 11:14 PM
I have a 52 Chevy 1/2 ton and did a similar thing with the following differences: The saginaw 4 speed may fit very nicely behind the 51 216 ci bellhousing mine did on the 52 even with a 235 bolted to it. Try to find yourself a 2 grove transmission input shaft saginaw. You will need to keep the 51 bellhousing because of the rear support mounts. The 2 grove may be hard to find, however a 3 will do ok. You also say or imply that this kit will allow you to use your orig chevy 4.11:1 rear. You will be gaining nothing really, because in the end you still be 1:1 different transmission or not. Recommend that you consider saving some of that 400+dollors and get a junk yard opendrive rear end, GM of course. Stay away from the **** 9's as they take 1 to 2% more HP to turn over because the pinion sits lower. However put in a **** 9 if you will be someday putting in a big v8. Anyway the GM rears you can get all day for $100. and you can pick the gear ratio. The ideal ratio in my view is a 3.08:1. This will allow you to run on the interstate and around town real nice at 60+mph. Some say the 3.55:1 are ideal, but to me too high rpm with the 6 cyl. I'm very familiar with the Patricks products and recommend his Saginaw shifter. Its a Hurst Comp shifter with a mounting plate that allows it to be moved up to use with your orig seat. If you are not confortable with tearing into the trans to check it out take to a local trans guy. The 52 chevy 1/2 ton rear measurements were 56+1/2" (inside flange to flange). Take your own measurements and go shopping for a similar rear from a leaf spring rear. It doesn't need to be exact. Just be sure it fit inside the rear fenders and looks ok. You'll know. Just measure from the same location. Nova rears, Olds rear, 92 up chevy truck will be close. Thats ok, you'll have to change the spring purch location and set the pinion angle, not as hard as everyone makes it. And you will need a new driveshaft about $150. If you would like to contact me Chief post a private message thru this forum. Good luck to you.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#41784 10/02/2003 1:55 AM
Old Navy, I don't know if I can help much but there is a lot of wisdom in the advice to go open drive shaft. I resto-rod my 37 pickup and used a malibu rear end. I believe it was an 80 model and has a 3.71 (maybe its a 3.73) and does real good. The best part is its free. If you have some guys around there who build race cars and drive around their shops.You will probably find a rear end out of a chevy or firebird that they will give you to haul away!!! I don't know the difference in my spring perches vs yours but the malibu fit right down on my so I used the original springs. Take the money you save and drop a small block in it and have some fun! smile
