1 members (2-Ton),
133
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | There's a valve that can be turned on and off by the water pump, leading to the radiator. I was wondering if any of you guys might now which position(up or down) is open or closed, and if I should have it open or closed. ????????? | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Leave it open better cooling that way also if it is a ball valve with a lever the lever is direction of flow. If in doubt warm her up and put your hand on the heater box T/C Steve | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Thanks. It's got a lever on it and I don't have anyway of telling which was open or closed. I'll see about the heater box though. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | OH, correction, it's not leading to the radiator! Don't know why I said radiator though. It's to the heater. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | In a way you were right anyway. A heater is just a small radiator.  As for on or off there are two trains of thought. One is to leave it on for the additional cooling it provides the engine although that puts more heat in the passenger compartment. The other is to put the valve on the "feed" side and shut it off during the summer. That helps keep heat out of the cab AND keeps pressure off of the heater core. It all depends on personal tastes and there is no "wrong" answer.
| | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | When I said "on or off" I meant should the valve be on or off, but not off of the engine. Thanks for the help, I messed with it and turned it both up and down and when I pulled it up it let in the coolant since the hose was warm so I figured that one out. | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | Leave it off. That is an old trick they used to use when the heater valve would fail. open - heat - - closed - no heat | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | 54tow, it's not just that. It's also just in case your heater core ruptures. It could just be a safety precaution. | | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | Doesn't matter where you mount the shut-off valve - either intake or outlet of the heater. If the valve is turned off, there is no flow through the heater hoses either way.
The purpose of this valve makes sense especially for hot summers. During the hotter months, you want to turn it off, so all the coolant can flow through the radiator for vital cooling. If you leave the valve on, a portion of hot coolant bypasses the radiator at all times and will just return to the block uncooled. The small heater core does get hot, however never removes enough heat to cool an engine and certainly doesn't help in keeping the cab cool. Don't know how hot your summers get, but in the desert you take as much cooling as you can get and a valve can help.
AD trucks had an automatic heater valve that was installed inside the cab on the fire wall. It measures the internal cab temperature and turns the heater valve on and off automatically ... a 'cool' accessory indeed.
| | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Oh, if that's the case, I'll leave it off. I thought that it would keep the engine from getting more coolant for some odd reason, so I'll just leave it off for now. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | To put the valve on the "feed" side keeps coolant from going to the heater core which is good if the heater core leaks.....which you will want to find out one day! It will help the engine to run a little cooler if it circulates but I'm not sure how much cooler. What that does is give the water a "longer" route to flow and cool off some and the heater core will disipate some heat if that is the intent during a lot summer if the engine starts to overheat. BUT if you want to stop the water flow all together due to a bad core some folks just take the ONE hose and make a "loop" to where the coolant comes out and then right back in without using a valve or even going to the core. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Well, for the little bit that it ran before I ran into fuel problems(gas not wanting to go from can to carb) it didn't leak any, so that is a good sign. | | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | I think there is some "mis-information" here... the valve only stops the flow of coolant. But because the other heater hose does not have a valve, the heater core is always under pressue. So if the core leaks or ruptures, this wil not stop the coolant from leaking out.
Just thought I should clear up that point. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Doesn't matter where you mount the shut-off valve - either intake or outlet of the heater. If the valve is turned off, there is no flow through the heater hoses either way. Gotta disagree. If it's on the "pull" side of the pump & turned off the pump is putting pressure on the heater core all the time even when no fluid is moving. If the valve is on the "push" side & turned off the heater core isn't under pressure & has less chance of failure if it's a bit weak.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I think there is some "mis-information" here... the valve only stops the flow of coolant. But because the other heater hose does not have a valve, the heater core is always under pressue. So if the core leaks or ruptures, this wil not stop the coolant from leaking out.
Just thought I should clear up that point. If that was true the suck side of your vacuum cleaner would be a compressor instead of a vacuum. Same principle. Putting a valve on the push side won't stop a leaking core from dripping I agree BUT it will take the pressure off & possibly save a core that is weak but not leaking yet.
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | The small heater core does get hot, however never removes enough heat to cool an engine In and of itself it won't cool the engine but running the heater with the fan on does aid cooling. It's an old trick to help cool off an overheating engine. I've done it myself and it does help. It doesn't do anything for the occupants of the vehicle though  | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i took this off my 235 and installed it on my 292 http://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=DSC00313.jpgas i remember when i had a leak that was only detectable when the core was mounted as that mounting caused a slight bend in the core,,,,, i used the shut off valve to help diminish the flow & pressure off the core til i got round to soldering it . any way you put it ... it did help. or in a pinch simply bend the hose back on itself ... temp.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | The heater valve regulates flow through the heater core. The radiator cap regulates pressure of the cooling system.
Early Chevy cooling systems had zero pressure radiator caps. The later 4-7 lbs. caps raised the coolant boiling point.
I once had both a radiator and heater core that only leaked when coolant was under pressure. A zero pressure radiator cap reduced the leaks, until I could fix them.
| | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Well, thankfully nothing is leaking yet! | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | When I installed the waterpump adapter I put on the original I think shut off valve since a heater will be installed soon,I noticed the motor warming up better with it flowing all the time but I will keep it shut off in the summer when the heater is installed. Jeff | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Well guys, I have it on and I don't notice any difference heatwise with it on or off, there's too much floor missing to tell! | | | | | Joined: Nov 2020 Posts: 366 'Bolter | | 'Bolter Joined: Nov 2020 Posts: 366 | Looking into this.. how about having two shut off valves, one for each hose thus shutting off ALL pressure to the heater core in the summer? Any takers?
'38 1.5ton; "The stuff is as tough as woodpecker lips"
| | | | | Joined: Oct 2021 Posts: 6,822 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,822 | Looking into this.. how about having two shut off valves, one for each hose thus shutting off ALL pressure to the heater core in the summer? Any takers? Well, it's a zero pressure system so I don't think it's going to make any difference at all in the health and longevity of your heater core. My '39 Packard has a factory installed heater and factory installed shutoff valve on the inlet hose. If the designers thought a second shutoff valve would provide any benefit, I'm sure they would have installed one.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2019 Posts: 4,482 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,482 | I’m locking this thread as the OP’s question has been answered.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | |
