| | | Forums66 Topics128,265 Posts1,058,365 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#41630 03/12/2005 5:27 AM | Joined: Sep 2001 Posts: 109 Member | | Member Joined: Sep 2001 Posts: 109 | I work at a Caddy dealer, and can't get anywhere with this one.........
I need to find out if anyone can modify a 4L60E to not require computer controls. I have to use late model, because of the removable bellhousing, otherwise I'd just get a 700R4.
I've got a 2.2L 4 cyl. for my daughter's Nash Metro project, and it has a narrow bellhousing pattern.
I've called Hughes, they can't do it. Our tranny guys at work have different opinions and don't know........
Worse comes to worse, I'll just run fully computerized OBD2 driveline, but carbs are cooler!
John Kennedy 1950 Suburban street rod Pics in the Gallery....... new site up! http://home.joimail.com/~kennedyjp/
#41631 03/12/2005 6:18 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The 4L60E is controlled by electronics, no way that I know of to convert them since the valves are operated by solenoids. TCI makes a computer to run it for you, but it isn't cheap. http://tciauto.com/electronics/index.htm Summit sells them. This is from Novak Earlier engines can be joined to the 4L60-E by use of a GM Controller, #12497316. Carbureted engines will require a Throttle Postion Sensor.
Fred 52 3600 69 C-10
#41632 03/12/2005 2:39 PM | Joined: Oct 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 112 | | | |
#41633 03/13/2005 3:55 AM | Joined: Sep 2001 Posts: 109 Member | | Member Joined: Sep 2001 Posts: 109 | Those are both good ideas, I'll check them out! If Im gonna spend $$$$ for an aftermarket box, I may as well scrounge up more GM factory PCM/TCM parts and go stock. I'm kinda hoping that the cases are similar, and I can just swap valve bodies and drill/add a TV cable, and fill the big wiring hole. I do a fair amount of machine work here at the house, so Im up for most anything! Thanks!
#41634 03/13/2005 2:52 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Snag a wrecked S10(everywhere around here) & use the PCM for the tranny & use injection on the engine. Brian | | |
