5 members (mick53, Grandpa C., lumbersawyer, Nick in Manitou, Wally / Montana), 127 guests, and 3 robots.
Topics128,264
Posts1,058,357
Members48,485
I work at a Caddy dealer, and can't get anywhere with this one.........
I need to find out if anyone can modify a 4L60E to not require computer controls. I have to use late model, because of the removable bellhousing, otherwise I'd just get a 700R4.
I've got a 2.2L 4 cyl. for my daughter's Nash Metro project, and it has a narrow bellhousing pattern.
I've called Hughes, they can't do it. Our tranny guys at work have different opinions and don't know........
Worse comes to worse, I'll just run fully computerized OBD2 driveline, but carbs are cooler!
John Kennedy
1950 Suburban street rod
Pics in the Gallery.......
new site up!
http://home.joimail.com/~kennedyjp/
The 4L60E is controlled by electronics, no way that I know of to convert them since the valves are operated by solenoids.
TCI makes a computer to run it for you, but it isn't cheap. http://tciauto.com/electronics/index.htm
Summit sells them.
This is from Novak
Earlier engines can be joined to the 4L60-E by use of a GM Controller, #12497316. Carbureted engines will require a Throttle Postion Sensor.
Fred
52 3600
69 C-10
http://www.bowtieoverdrives.com/index.shtml Try this it may help.
Jbennett
40 burb
Those are both good ideas, I'll check them out! If Im gonna spend $$$$ for an aftermarket box, I may as well scrounge up more GM factory PCM/TCM parts and go stock. I'm kinda hoping that the cases are similar, and I can just swap valve bodies and drill/add a TV cable, and fill the big wiring hole.
I do a fair amount of machine work here at the house, so Im up for most anything! eek
Thanks! wink
John Kennedy
new site up!
Snag a wrecked S10(everywhere around here) & use the PCM for the tranny & use injection on the engine. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
