| | | Forums66 Topics128,138 Posts1,056,440 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | hey guys. i live here in south florida, and keep a waterproof cover on my truck at all times, since it sets outside. i noticed today that the wood floor bed is getting mildew. how do i get it off easily ? i was told the wood was treated, but with what i dont know. please dont say to remove allt he wood. is there a way to get rid of the mildew easily ? thanks much. leonard | | | | | Joined: Feb 2000 Posts: 5,223 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,223 | Go to the local hardware store and get a deck wash, it should clean it off. Joe | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | agree with joe h ,that would be my first guess...........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | thanks guys. i looked at the side of most deck wash bottles. and they say not to get on metal. so im gonna try some simple clean and see what happens. thanks.
leonard | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | You could try blowing it off with a pressure washer, too. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Len - vinegar will kill mildew, although it's also corrosive so it'd need to be hosed off well afterward ... it's the humidity and dark that encourages mildew, you might find that leaving the tailgate open so there's some air circulation in there will slow down the reoccurance
Bill | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | i tried the simple green, diluted, and scrubbed with a plastic brush. hosed down,a nd when it dried, it left those areas i scrubbed dry looking, like it took off some of the finish. but it did not remove the mildew. next i will try vinegar, hopefully monday. looks like i will be taking the wood planks out sooner or later to refinish them with a darker stain and clear urethane. any other ideas would be greatly appreciated. thanks. leonard | | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | I'd try what Hotshoe recommended. If you don't have a pressure washer or know someone who does you could run the truck down to a do it yourself car wash.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if the simple green left it looking dry, then the finish on it was just an oil, which most astringent cleaners will suck out ... easy enough to re-oil, but it's the oil that's feeding the stuff so you may have to sand it to get rid of all the stain .... you'll avoid the fungal problems if you put a hard finish on it, urethane as you say - I've had good luck with 'Minwax Helmsman Spar Urethane' on outdoor wood
Bill | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | thanks guys. do you think just a pressure clean, even from a car wash, would get rid of the mildew ? guess i could always just try it. man, it looked really goo, then this. i was wanting to redo the wood in the future, getting a darker stain, then eurethane, but wasnt really looking to do it this soon. i am waiting on 2 rear wheels from centerline to see if they will clear for more lowering, then wated to do a power disc front brake system. maybe i could squeeze the bed redo between these projects. LOL. so, lets say i can get rid of the mildew stain with a pressure washer. then what sould i do to it ? is there a quick fix i can do to it without removing the wood rom the bed, then do it the correct way when i ahve the time ? thanks much. here is a pic of the bed when i first bought it. http://s251.photobucket.com/albums/...00/?action=view¤t=DSC01284.jpgthanks guys. leonard | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | You will have tons of problems trying to get those stains off oak. Any moisture left on oak turns it into a greeenish , grayish stain. About the only way to get rid of the stain is to sand the wood. It may go so deep that the board will be dished out with all the sanding. The bed must not have had a good topcoat of urethane on it to stain in the first place. Somebody above said it may have had only an oil finish on it, maybe that is the case. But I would bet that you have moisture stains that only can be sanded out. | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | I think Oxylic acid removes stains on wood really well. It is what I've used to remove stains from hardwood floors. I have no idea of it's effect on painted or bare metal surfaces. | | | | | Joined: Mar 2008 Posts: 38 Apprentice | | Apprentice Joined: Mar 2008 Posts: 38 | Use half-cup ordinary bleach to one gallon hot water. That will kill the mould fungi. And it will lighten any staining. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | thanks again guys. coach-frank, i love the look of your bed. laurance, i will try the bleach and water trick on monday. thanks so much guys. would like to remove the mildew easily without romoving the wood from the bed. thanks again. leonard | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Leonard, try some laundry BLEACH diluted 50/50 with HOT water on a samll spot let it dry and it should kill off and bleach out the mildew. might be worth a try? Tim | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | sure will try the bleach. didnt get around to it monday. hopefully this coming saturday.
tim, are you suggesting to use the 50/50 mixture and let it set after applying, and not rinse off ?
thanks again guys. leonard | | |
