2 members (Otto Skorzeny, MickeyP), 132 guests, and 2 robots.
Topics128,088
Posts1,056,408
Members48,443
#415978 05/23/2008 2:39 PM
I have just purchased this truck. The previous owner said "It needs a new master cylinder". What he actually meant was "I rebuilt the master cylinder and then stripped out the brake line fitting at the banjo." I need that fitting. I have looked in all the usual places and cannot find the fitting. Does anyone know of a supplier? Is there some kind of workaround that I can put together from the local auto parts store? I will eventually change to a dual master cylinder and redo all the lines and brakes, but right now I would like to get it patched up so I can at least move it around in the shop. Thanks, Hugh.
Check out our Flaps Brass fitting selection....
GMC: Get More Cash...
1958 GMC
My Webshots photos
yes, those parts are non existant, don't come with a new MC either ... some time back I took the banjo to NAPA and went thru all their stuff and faked something that worked, but failing that you'll need to find good used, a post in the parts wanted here might turn something up
and welcome to the garage Hugh, always nice to see another TF series [pictures, we love pictures!] - there's some folks here who may have what you need, and always lots of good info
