1 members (Hotrod Lincoln),
112
Mod | | | Forums66 Topics128,142 Posts1,056,491 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | What do you use? Simple sheers? Nibbler? Other?
Basic stuff that I haven't mastered.
Thanks, Keith | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | The order I would place things is;
A sheet metal sheer is going to give the straightest, cleanest edge. A nibbler (at least the ones I've used) cut tiny round bites out of the metal so you can go in any direction (round corners, etc.) A nibbler is as straight as you make it go and leaves a somewhat serrated edge. A plasma arc cutter can cut in any direction and is as straight as you can make it. You can use a straight edge of some sort to help the cut be straight. The edge is burned but can be pretty nice. A cutting torch will leave a burned edge and will take some practice to leave nice edges.
Plasma arc (to me) seems my choice for space and versatility. | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | What about a "whizzer"? (die grinder with a cutting blade) | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | zip wheels on a die grinder will usually warp a sheet if yer making much of a cut - I love my new 'air scissors', did a number on the roof of a 52 sedan [sorry Joker  ] in minutes to supply a patch for the nose of daBusBill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Anything like a die grinder or dotco that uses abrasion for cutting is apt to warp a flat panel due to the heat generated. An exception to that would be if the cut line is fairly short or if you take your time & do the cut in segments so the metal doesn't get too hot.
| | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | OK - thanks for the clarification.  | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | I've always heard this was the "gold standard" for cutting sheet metal. Beverly Shear After using it a few times, I would agree with them. It's a real time and effort saver.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | It's a nice piece of equipment but it won't work if you're cutting out rust & fitting a patch panel on a cab corner.
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | If you only need afew things cut straight take them to a hvac shop and have them cut them on their sheer. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | A shear first but a nibbler works well with a straight edge Dan | | | | | Joined: May 2005 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 45 | A cute little trick that I have used when I didn't have access to a shear is to get two pcs. of bar-stock, like .250" x 2.000" or .375" x 2.500", size is not that all important, just as long as they are longer than your pc. of sheetmetal and that they are at least .250" to 1.000" thick. (cold-roll bar stock is better because it has a nice sharp edges on it). If the length of the sheetmetal part is important you can scribe you a line on it where you want the final cut to be, this helps to setup the sheetmetal part to be cut. Then cut your sheetmetal with a grinder, bandsaw or a nibbler as straight as you can but about 1/32" to 1/8" or so, longer than needed. Then sandwitch your sheetmetal between the two bar-stock pcs. and c-clamp all 3 pcs. together at the ends of your sheetmetal so that your sheetmetal just sticks out from between the edges of the bar-stock about 1/32" or 1/16", or clamp so that the edge of the bar-stock is right on your scribed line. Clamp on the back side of the bar-stock so you have access to the trimming edged and the c-clamps are not in your way. The two pcs. of bar stock must be exactly on top of one another with no offset or step between them. Then use a small hand grinder like one of those 3" right angle die grinder with a FINE grit dics and grind your sheetmetal down to the edge of the bar-stock. The bar-stock also acts like a heatsink and you will not get any warpage. Sometimes I put some 'layout blueing' on the edges of the bar stock and that lets me know when to stop the grinding. You don't want to grind the bar-stock, just grind the sheetmetal down to the bar-stock all the down the length of your sheetmetal. Then remove the c-clamps and dress the edge of your sheetmetal with a hand file just enough to remove the grinding burr.
This is not as hard as maybe I have made it out to sound. But a person can get good enough at doing this that is is hard to tell the part was not cut on a shear.
Yes, it does involve some time to do this but it does make a nice straight clean edge. I have two pcs. of .500" x 2.000" cold roll bar-stock 36" long just for doing this at home. I have worked for a sheetmetal company for 30 years and would often have to do this if we had a part that already had forms or bends in it and it would not fit under the shear machine hold-downs. | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Thanks for the detailed reply ED-I could see where that would work well under the right circumstances
Fire-That would be nice to work with-My father had one when we were kids..It had that hold down feature which would be a great benefit...My father gave it to my brother :o(
Have a great holiday everyboby...looks like nice weather
Keith | | | | | Joined: Apr 2005 Posts: 15 Apprentice | | Apprentice Joined: Apr 2005 Posts: 15 | I have used a cutoff wheel in a 4" angle grinder with great results. Ed | | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | Martinsr's post "Example of excellent patch panel trimming tool" #124331 - 01-30-2007 10:13 PM in paint & body This | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I sure like the air shears for cutting sheets ... just gotta find a creative use for the leavings  Bill | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | that's a nice cut...
the leavings?: how about Chritmas tree ornaments? Paint em silver or gold ...maybe with some fake snow
Keith
