| | | Forums66 Topics128,021 Posts1,055,348 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | Hey guys, hope you all had a good winter. Now it's time to get our babies roll'in. I got my truck out of storage yesterday and drove it home 35 miles back to my house. The only problem is, I know my heater core leaks, so last fall I bought a new shut-off valve for the water pump because the old valve screw wasn't seating completely and the previous owner had put a plug in the return so there was no chance of coolant even reaching the heater core in the cab. Well, it still leaks into the heater core and is dripping out of the hose where it is clamped snugly on the fire wall. My question is, could I simply use one piece of radiator hose and run it from the shut off valve (leaving it open) and connect that same piece to the return on the water pump housing? Basically bypassing the heater completely. Any and all suggestions and input really appreciated in advance. Thanks for your time. Jeff Lincoln, Nebraska | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jeff,
Making the 'loop' as you describe is a common way to bypass a leaking heater core..fast and easy!
Stuart | | | | | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | Are there any problems with doing this or any special I should be aware of? I can leave the shut-off valve open then can't I? Jeff | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jeff,
Nothing special to be aware of. Just loop the hose, leaving the valve open or closed...no diff! The heater is a 'extra' so technically you could pull the hose and cap the holes with pipe plugs.
Stuart | | | | | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | Could I get some pipe plugs at a local hardware store? I've never seen anything like that from Jim Carter or the other vendors. Thanks so much for the tip and information by the way. It has been stressing me out a bit. I'm afraid the pressure will build up and it will blow while I'm driving it. Jeff | | | | | Joined: Feb 2008 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 70 | put rubber caps over water pump intake and discharge fittings....and put rubber caps over heater intake and discharge copper tubes.......tighten with hose clamps.........most stores like advance.....o'reillys....napa carry radiator hose caps.... | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Just loop the hose and keep it long enough not to get kinks in it. It won't cost you a thing unless you have two different size hoses. Then just get a hose adapter for a couple of bucks. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hell Jeff, just tie a knot in the hoses, C-clamp it, stuff some big bolts in and clamp them, loop it around, pipe plug the outlet and inlet if your not going to use the heater any more! It's just a tap off the cooling system and it really doesn't make any difference whether its there or not. Remember it was an option on most of these old trucks so a lot of them simply didn't have any thing plugged into the water pump. Denny G
Denny G Sandwich, IL
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | When I pulled my heater for repairs I simply put a piece of copper pipe in the ends of the hoses and clamped them. I then suspended it from the rad support bars for the interim. Ran it all summer that way. However as is written above just make a simple loop or put plugs in the pump. no problems. Incidentally I keep that piece of copper in my on board tool box in case the heater blows while I am away from home.
| | | | | Joined: Jan 2007 Posts: 99 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 99 | Thanks for all the suggestions and information guys! I appreciate it. Jeff | | |
