3 members (klhansen, Steelonsteel, UtahYork), 134 guests, and 2 robots.
Topics128,183
Posts1,057,262
Members48,467
wondering if i will need to get something else or if i can live with the original radiator. any 327'ers out there?
1950 GMC 1/2 TON
1952 3/4 DUALLY
1952 CHEVY FRAME,CAMARO CLIP,327,700R4 WAITING FOR GLORY
More horsepower means more heat to dissipate, so you will need more radiator. If you have a good local radiator shop, they should be able to help you.
Fred
52 3600
69 C-10
The 52 radiator will not have the pressure rating the 327 might need to run. I'd be more comfortable with an aftermarket item made to fit the core support but with a 15+ PSI pressure capability. Be sure the heater core also gets replaced with a higher pressure item.
Heed Fred and Jerry’s advice. They ain’t pulling your leg.🛠
You can probably sell your '52 brass radiator to someone for as much or more than what a new aluminum radiator costs. There are some available which are shaped like the originals and are hard to tell apart after you paint the tank black. I have ordered 2 of them for $200.00 delivered to my front porch.
Carl
You can buy and original style that can stand the pressure but it'll cost a lot more than the aluminum one. Luckily I bought my aftermarket original (with automatic tranny cooler) back when I could buy it for $245 which was quite a while back.
Today, or a year ago, I bought a Walker aluminum delivered to my front door for exactly $200 and it came with a nice high pressure radiator cap and automatic cooler in the bottom. Fit quite well.
