4 members (Hambone, 2-Ton, Otto Skorzeny, TUTS 59), 147 guests, and 3 robots.
Topics128,084
Posts1,056,087
Members48,434
#414019 05/18/2008 2:00 PM
Installed a new clutch kit into my 68 Chevy...did the rear main seal and u-joints as well...
the clutch feels strange...it works...but it seems to put the truck in gear much faster than the old one....like half the distance of clutch movement...whats it supposed to do?
Thanks in advance...
pack,
I would think ya need to adjust your pedal a bit to get back the "FEEL" ya used to have seems your new one is just a bit tighter than the old.
Tim
1952 Chevy Shortbed
Photos in Photobucket
The only adjustment that you have on your clutch should be for the throw out bearing clearance. Everything else is set by the physical design of the disc and pressure plate.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Adjust your pedal free travel,so you have about one inch of free travel before it engages. In other words when you depress your clutch pedal there will be one inch of free travel before you feel it engaging. Hope this come thru clear.
Denny,
I havent dealt with a old school clutch in a while but I was almost sure you can adjust your pedal travel by the rod to move your pedal up an down ..to get the feel ya want ??.. like releasin quick as to a a few inches of the floor ?
I might be wrong.
Tim
1952 Chevy Shortbed
You need to end up with "free-play" in the pedal when the clutch pedal is fully released. That way the throw-out bearing isn't always in contact with the pressure plate, allowing it to spin at all times. That would wear it out in short order. A new clutch will feel different than an old one and apply closer to the floor which youy'll get used to quickly.,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Free travel,not free play.
Riding in the Passing Lane
Each clutch will have a different "feel" to it. It should take soft even pressure going down & engage smoothly without any chatter or abruptness.
1972 Chevy c10 Cheyenne Super
Thank you guys so much for replies..
Dale-yes you are loud and clear...starting to make sense to me now...
And Denny - I think U r right as well...the old disc was worn smooth...down the rivets....so far so good with the new kit...no grinding, resistance or chatter...just feels wierd...and judging by all the reponses I will have to be the one who adjusts to it...
I had put in clutch cables before...but never got this deep into it...and the surgery has changed the trucks reaction...
The gears engage at approxamately 3 inches from the floor...used to be 5 or 6...and I thought that was correct!
You guys are awsome...tell me more....
